Flywheel replaceable friction surfaces
Old Jan 12, 2004 | 11:30 PM
Heath's Avatar
MAGNUM SE7EN
How much do these generally run?
Old Jan 13, 2004 | 01:00 AM
Siraniko's Avatar
RX for fun
RB replacement friction plate runs appx $75. It says it will fit both 215 and 225....ITS A LIE. I bought one appx 5 years ago and it was for a 225. Same part #.
Old Jan 13, 2004 | 06:16 PM
rx7gslse's Avatar
EX Pres of DFW Drunks
yep.. I did the same.. Bought a usd flywheel, new friction plate..
turns out the plate was for an 225mm flywheel and the flywheel was a 215mm.
I still have it ifyou wnat to buy it. (friction plate that is) I'll sell it for less than RB does, never used.... PM me.
Old Jan 15, 2004 | 12:32 PM
slowautoxr's Avatar
autoxr/rallyxr
I have an RB aluminum flywheel I need a friction plate for. I too don't know what size I have. What's the difference between the 215 and 225mm friction surfaces.
Old Jan 15, 2004 | 02:24 PM
Siraniko's Avatar
RX for fun
10mm. j/k. I can be made tho. I've visited 10,000 RPM in Palmdale CA several years ago. They looked at the flywheel and told me that they can make it. I didnt follow up since I found several old friction plates in my garage (Never throw things away) and my buddy was able to clean it up.
As long as there are no deep scratches, not warped and no exposed screws, it can be re-used. Also, I used that flywheel along with carbon kevlar disk til I switched to stock flywheel and puck clutch.
whinin
Mar 30, 2019 07:53 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
