won't pass 55mph???
Old Jan 11, 2004 | 09:54 PM
rneoaz82's Avatar
won't pass 55mph???
Okay my 83 kicks in some good power once i get it running in the morning and after about 10mins of driving she totally sucks *** on the road. I try stepping on the gas and she studders. Its even worst on the highway to college when the speed limit is 65mph and she hits 55mph then begins to slow down with my dame foot stepped all the way down on the gas.
What suggestions i've gotten on the forum. Here they are, fuel filter,adjust the gas cable, the secondaries, catalyic converter. I've tried every one of the these suggestion and none have resolved my problem.
One thing that i've been taking into consideration in doing is replacing the return fuel line because she gets horrible gas mileage i mean like 8 mile to the gallon. yup its bad. I've noticed that the front fuel bowl has been getting full and know its supposed to be only at half.
Any help will be cool!!! thanks...
Old Jan 11, 2004 | 11:52 PM
heb09's Avatar
spark plugs, dizzy? Clean em or replace em.
Old Jan 12, 2004 | 06:14 AM
Steve Shulz's Avatar
Re: won't pass 55mph???
Its probably flooding like a ****. My carb 12aa gets 23+ mpg. It should always be in the middle, both front and back. Float issues? Do you have time to do a carb rebuild? I think you need to. I'll bet you could pump the gas peddle while its running and cause the same prob.
Old Jan 12, 2004 | 07:18 AM
DONNA's Avatar
have you pulled the plugs, will show if running rich, inspect the check and cut valve (by fuel pump) goes on one way only so make sure , and your cats not clogged.
Old Jan 12, 2004 | 10:27 AM
Also when mine "ice's up" it will display that behavior. Not that yours is iceing, but that its flooding bad. Carb kits are cheap and they arent that hard to rebuild. Just make sure you have the room and time.
Old Jan 12, 2004 | 05:29 PM
rneoaz82's Avatar
One question how are the spark plugs supposed to look? What can be a cause for the floats to fill up?
Old Jan 12, 2004 | 05:34 PM
DONNA's Avatar
not wet or black, brown/tan good, needle stuck in seat, gummed carb, sometimes just tapping above where the the float is will release the needle.
the bowl overflowing is from a stuck needle...in most cases anyway....
Old Jan 12, 2004 | 05:42 PM
rneoaz82's Avatar
okay thanks i'll look into that because i can't remember even having my carb rebuilt. I'm still gonna try and replace the fuel return line.
Old Jan 13, 2004 | 03:44 AM
Gatorgunner's Avatar
Amazing no one has suggested one of your coils is bad.
One of my coils went bad and my car was doing the same thing yours is. Pull the wire from one coil (at the coil, not the dizzy) and have someone crank the engine, you should see sparks all over the place, if not then you have a bad coil. If you see them, then test the other one.
Just my two cents as usuall.
Old Jan 13, 2004 | 12:10 PM
rneoaz82's Avatar
i think the coils are the one's that are next to the battery on the left side of the fender, right?
Old Jan 13, 2004 | 04:28 PM
yes
squirrels
Sep 1, 2024 09:52 AM
Red-Dragon_Akuma
Sep 28, 2015 06:09 AM
lnlreaper
Sep 27, 2015 09:59 AM
