fusible link
Old Jan 10, 2004 | 08:55 PM
bizarro's Avatar
fusible link
k...so i tried pulling my fusible link out to clean and its tough getting in there to get all that corrosion out...i tried best i could and although i've got better contact it still cuts off if i move the center link just a little...so i'm assuming the contact still isn't good...although its better than before
so my question...besides mazda where else can i get a fusible link block for my 84 gsl-se? also, i see mazdatrix has fusible links for 84-85...the black and the brown...but a gsl-se has more...is my only option mazda?
thanx
Old Jan 10, 2004 | 08:57 PM
Steve Shulz's Avatar
Junk yards rock! Get some contact cleaner to spray in there or use WD-40. The WD will evaporte but it will help you nail the issue.
Old Jan 10, 2004 | 08:58 PM
wwilliam54's Avatar
it WILL run
make a fuse box
Old Jan 10, 2004 | 09:03 PM
alien_rx7's Avatar
Interstate Chop Shop CEO
Originally posted by wwilliam54
make a fuse box
I agree. LTProject on here made a fuse box for his FB turbo project. Turned out very nice and the engine bay looks more modern with it in there. I plan going the fuse box route also when I get the parts together.
Old Jan 10, 2004 | 09:11 PM
Fuse box idea = junk yards rock! Sure you can get one cheap. Very nice!
Old Jan 10, 2004 | 10:01 PM
hanman's Avatar
check my old posts for a second gen swap fuse box for the links.
Old Jan 10, 2004 | 10:57 PM
mazdaverx713b's Avatar
Have RX-7, will restore
you can see the post on the GM alternator swap. it says something about remaking the fusible like box.
Old Jan 10, 2004 | 11:07 PM
LongDuck's Avatar
84SE-EGI helpy-helperton
SE's also use a Green Fusible Link for the Fuel Injection system (labeled 'INJECTION') that is rated for 0.5sq which is higher in current carrying capacity than the brown links (0.3sq). In other words, you can't replace green with brown and expect it to work, as it will likely burn out in a short period of time. Also, replacing with Black link (1.25sq rating) will allow too much current to pass and could burn out your fuel injection computer (ECU).
This information is straight out of the FSM for the 84SE. As a quick diagram, the following is a top-to-bottom representation of the link description, the color, and the rating;
(note: 13b RE-EGI engine, ONLY, 12a only has the bottom 3...)
INJECTION - Green link - 0.5sq rating
COMPUTER - Brown link - 0.3sq rating
(separate block, and common to 12a models, include)
RETRACTOR - Brown link - 0.3sq
MAIN - Black link - 1.25sq
HEADLIGHT - Brown link - 0.3sq
To ensure that you're providing the proper current carrying capacity and not risking damage to these systems, you should only replace the bad link with the CORRECT color and capacity. HTH,
Old Jan 11, 2004 | 12:24 PM
rotarydankus again's Avatar
any 90 -up gm bonneville olds 88 buick le slobber you name it has a primary fuse block filled with maxi ato style fuses, 6 maxi curcuits and 9 ato fused cuircuits, i have all my accesories fused and replaced the link box with this and still have curcuits left over for additional mods , dankus salvage yard price 5 dollaars
edgars95rx7
Link Vi-PEC
Oct 1, 2015 01:59 PM
jdmbrendan
Oct 1, 2015 01:29 AM
TeamRuffRacing
Sep 30, 2015 08:13 PM
pfsantos
Sep 30, 2015 01:29 PM
