Sponsored by: CARiD
won't start flooded ???
Old Jan 10, 2004 | 02:56 PM
sj_rx7nut's Avatar
My '91 convt. won't start. It was running great until it got cold today (15 degrees). I kept trying to turn it over and I think I flooded it.
I have a fuel shutoff switch, if I turn it off and let it sit until tomorrow will it un-flood on its own or do I have to do something ?
Old Jan 10, 2004 | 03:07 PM
wwilliam54's Avatar
it WILL run
you have to put the gas pedal to the floor and crank it for several seconds
it wont unflood by itself
Old Jan 10, 2004 | 03:11 PM
sj_rx7nut's Avatar
Should I leave the fuel switch off until I get it to turn over ?
Old Jan 10, 2004 | 05:00 PM
wwilliam54's Avatar
it WILL run
yuh
Old Jan 11, 2004 | 01:33 PM
sj_rx7nut's Avatar
I recharged the battery, pulled the plugs and cleaned them (top plugs were wet with gas). I put everthing back held the pedal to the floor and it still will not start.
The plugs had some build up on them, I cleaned them best I could with a towel.
It cranks, it just doesn't start. I'm off to pepboydsd to buy new plugs.
Any other suggestions. Could I have bigger problems then a flooded car ?
Old Jan 11, 2004 | 02:09 PM
sj_rx7nut's Avatar
I waited and got it started, but then one of the belts started to smoke. The outer most belt heated up on the cooling fan pully. I don't the cooling fan pulling was turning. Is it suppose to ?
please help
sj_rx7nut's Avatar
please help
Old Jan 11, 2004 | 03:37 PM
wwilliam54's Avatar
it WILL run
if the belt smoked then the pulley might be locked up
you should be able to turn all the pullies by hand
Old Jan 11, 2004 | 03:59 PM
sj_rx7nut's Avatar
Someone said water pump might be seized.
Is replacing the water pump a big job ? Is it an expensive part ?
Old Jan 11, 2004 | 04:33 PM
wwilliam54's Avatar
it WILL run
ive not seen a s5, but on a fb its pretty simple, it shouldnt be much different, pretty strait foward
get a http://www.victoriabritish.com/ catalouge
has most of the part you need, but a a tad pricy
also check napa they tend to be pretty cheap for me
and get a haynes manuel
edit: i looked in VB they dont have a pump, napa should and it shouldnt be expensive
Old Jan 11, 2004 | 08:21 PM
sj_rx7nut's Avatar
I think I found the problem, I got the car running, but it is leaking coolant like crazy. I took the rad cap off and there is ice in the spout.
I'm guessing the guy I brought the car from didn't put enought anti-freeze in. It was 7 degrees here yesterday.
I ran the car for about 10 minutes, when it started to heat up I shut it down. Do you think the ice caused any major damage ?
Old Jan 12, 2004 | 05:56 PM
wwilliam54's Avatar
it WILL run
hope not better look for cracks
Old Jan 12, 2004 | 07:39 PM
sj_rx7nut's Avatar
Its leaking at the front of the car, looks like below the radiator, I just can't see anything. The car starts fine so I'm hoping theres no major engine damage.
Does the rx7 have a freeze plug designed to pop if this situation happens ?
Do I remove both drain plugs (on rad and on engine block) to drain the system ?
Any suggestions on where to get a radiator, mazdatrix has one for $233.
Thanks for your responses.
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
PhillyFC
Aug 21, 2015 06:36 PM
Im faster
Aug 19, 2015 02:57 PM
