Many questions.
Old Jan 8, 2004 | 09:13 PM
JapandaAE86's Avatar
Question Many questions.
alright i posted here once before and asked a few questions about the N/A 13B from a 91 seven. everyone was really helpful.
so here are a few more questions:
stock apex seal sizes?... whats needed to go bigger? if anything? how does it affect compression?
has anyone ever tried to cryo the apex seals?
best/cheapest performance gains?
Stock Compression ratio?
who does their own porting?
Old Jan 9, 2004 | 04:27 AM
RETed's Avatar
Re: Many questions.
2mm x 8.0mm x 80.0mm
Why???  Bigger seals means more friction.  More friction means more wear, less sealing, less power...
It doesn't.
Why???  Harder seals mean more friction, which means more wear.  Mazda designed the seals to be softer than the housings for a reason.
"Best" does not equal "cheapest".
Cheapest bang for the buck - NOS.
9.7:1
I do.
-Ted
Old Jan 9, 2004 | 04:28 AM
I wish I was driving!
Re: Many questions.
1. stock apex seal sizes?... whats needed to go bigger? if anything? how does it affect compression?
2. has anyone ever tried to cryo the apex seals?
3. best/cheapest performance gains?
4. Stock Compression ratio?
5. who does their own porting?
1. Don't go bigger, especially on an N/A. larger seals don't seal as well, and thus make the least power.
2. yep. www.FC3s.org still does, IIRC.
3. putting on a cone filter and getting free flowing exhaust are the only major power gains for an N/A.
4. 1989-1991 N/A 13B had 9.7:1 compression rotors.
5. Lots of people. I do several different versions of porting styles.
Old Jan 9, 2004 | 01:40 PM
thanks for the replies guys.
i read some stuff on the differences between 1 and 2 piece apex seals and i think that 1 piece are supposed to lower compression.
i also read that they make ceramic seals... which are harder than the original seals and that they perform much better, and wont break nearly as easy(but are also a lot more expensive). thats why i asked about just cryoing the stockers.
Old Jan 10, 2004 | 04:34 PM
bump
Old Jan 10, 2004 | 04:51 PM
NZConvertible's Avatar
I'm a boost creep...
That's a weird one, and it's wrong.
Coochas
44
Nov 5, 2019 11:08 PM
sccarally
South RX-7 Forum
Oct 8, 2015 05:27 PM
Xepez
2nd Generation Non-Technical and pictures
Sep 22, 2015 03:15 AM
