Need window trim replacement.
Old Jan 8, 2004 | 07:50 PM
knightkarr's Avatar
Hey guys, here is another question for anyone that could help me out. My window trim is old and flaky on both driver's and passanger's window. Any one know of the procedure to replace these, and if possible could anyone give me the part #? Thanks
Old Jan 8, 2004 | 07:51 PM
Molotovman's Avatar
Ban Peak
Take oem out of the door, sand em down, and paint them.. Don't forget to clear coat!
Old Jan 8, 2004 | 08:06 PM
knightkarr's Avatar
i don't wanna paint them, though. I want the one from factory.
Thanks
Old Jan 8, 2004 | 08:12 PM
MtnRacer's Avatar
infini guru
Victoria Bitish or a place like Mazdatrix or your local dealer has them. You really ought to do what molotovman suggested though. They look BRAND new this way.
Steve
Old Jan 8, 2004 | 08:20 PM
Sir Rupert Hobo's Avatar
seven-less
dude, it's a simple fix.. you don't even have to paint them.. there is a spray on "rubber" like stuff in a can... it's called plasti-dip. i think the only place you can get them is napa.
it's only like $7... the oem trim is much more expensive and not worth it in my opinion.
i did this, and it looks flawless after months. check the link:
the good stuff
Old Jan 8, 2004 | 08:35 PM
86GXL's Avatar
Rotary ≥* Soul
I just pulled mine off (easy to do) and used a wire wheel to get the rust off and repainted them... looks brand new.
Old Jan 8, 2004 | 08:38 PM
Relisys190's Avatar
REINCARNATED
want new ones from the factory? Call your local Mazda dealer and get them. You'll pay roughly 100$ for a new set
-=Markus
Old Jan 8, 2004 | 08:39 PM
knightkarr's Avatar
the good stuff
Oh, that does look nice. I think i'll do that instead.
Thanks
Old Jan 8, 2004 | 08:59 PM
knightkarr's Avatar
How do you remove them from the door, though? Do you need to remove the side mirror for that? how?
thanks
Old Jan 8, 2004 | 09:01 PM
86GXL's Avatar
Rotary ≥* Soul
thanks
Simple... tag a thick rag and put it down so you dont scratch your paint and start from the rear and pry it up with a flathead sckrewdriver
Old Jan 8, 2004 | 09:07 PM
getbent69's Avatar
I've got a series 4 which comes with metal ones which rusted like yours did. Make sure you get the platic ones when you replace them. I paid $100AUD each and they were fairly straight forward to fit.
Old Jan 8, 2004 | 09:49 PM
seven-less
yes, you're gonna have to remove the mirrors, but that's pretty easy. first, there is a plastic piece that covers 3 mirror screws from the interior. take a flathead and pry it till it comes loose.. SLOWLY. or else you'll crack it. unscrew the 3 screws and remove the mirror... next, do what 86GXL said. except put the screwdriver where the white clips are. it'll be harder to crack it that way.
i think that covers it.
Old Jan 8, 2004 | 09:52 PM
86GXL's Avatar
Rotary ≥* Soul
You dont have to remove the mirrors... the trim only goes about a half inch under the mirror... just pry most of it up then slide it out.... WAY easier than pulling your mirrors off....
Old Jan 8, 2004 | 09:56 PM
seven-less
not for me.. it was easy to pull the mirrors out instead.. i didn't want to risk breaking them.
it's up to you.
Old Jan 9, 2004 | 01:18 AM
knightkarr's Avatar
great, that's exactly what i needed to know
Old Jan 9, 2004 | 01:32 AM
casio's Avatar
casio isn't here.
that link should be archived. 90% plus (okay, so this is just a guess) of our cars have THAT PROBLEM.
https://www.rx7club.com/showthread.p...ight=plastidip
scalliwag is a great guy. notice i did his crappy sig picture!
Old Jan 9, 2004 | 09:46 AM
seven-less
yeah, everyone should know about plasi-dip. keep these people alive!!!
Old Jan 9, 2004 | 12:34 PM
jon88se's Avatar
Eat, sleep, work, mod.
i bought mine new from mazda last year, $30 per door, no longer metal. they come on and off with clips, just remove your side view mirrors and unclip them...10 minutes for both sides
WANKfactor
Sep 29, 2015 01:14 PM
RXeckless
Sep 12, 2015 04:52 AM
