To much transmission fluid?
Old Jan 8, 2004 | 03:55 PM
Jester's Avatar
Question To much transmission fluid?
A while ago, I changed out the tranmission fluid in my tranmission to redline fluid. As instructed, I bought 3 quarts of it. Recently theres been a weird noise coming out of it or my clutch and some have suggested that it has somethign to do with the fluid. The haynes manual on my car says that it can hold 2.6 quarts. We had it jacked up in the front only so it was tilted back and we were able to fit all 3 quarts in there. So is it possible to have to much tranny fluid? And if so, is .4 quarts enough to cause damage?
Old Jan 8, 2004 | 05:23 PM
SureShot's Avatar
Seduced by the DARK SIDE
Too much will leak somewhere.
Any leaks?
If the clutch gets oiled, it slips.
Is the clutch slipping?
If it still bothers you pull the filler with the car close to level.
Any overfill will run out the fill hole.
Please describe weird noise..
Old Jan 8, 2004 | 05:34 PM
Davidov's Avatar
That's why you leave the fluid level check plug open when you are filling it up.
Take SureShot's advice, and drain a little out.
Old Jan 8, 2004 | 06:16 PM
NZConvertible's Avatar
I'm a boost creep...
Turbos have a very specific method of filling the trans. It's in the FSM and should be followed. This should also be done with the car completely level, so if you can't jack the car up and support it level (four stands) then take it a place with a hoist and have them do it.
Old Jan 8, 2004 | 11:12 PM
Jester's Avatar
Any leaks?
I haven't noticed any leaks, and the clutch doesn't slip. Its really hard to describe the noise, it hasn't been as bad recently, its like a rotating sqeaky noise, it does it in first, second, every gear even neutral.
Hummm, ok, my hanyes manual said something ot the effect of there are two fill holes and two drain holes in the tranny for this. My friend said that they didn't really matter, it all went to one chamber. So for the two drain holes, we picked the lowest one and for the two fill holes, we picked the highest one, so we only used 2 of the 4 plugs. I'm starting to worry that my friend was wrong..... it doesn't grind or anything, it kinda feel notchy, but its hard for me to compare. Its pretty much the only stick I've ever driven.
P.S. I don't know how NZConvertible knew but yes, it is a Turbo (if that makes any difference)
Old Jan 9, 2004 | 03:59 AM
I wish I was driving!
Same way I knew, we checked your profile. 1987 TII... In the future, please post that information to save us some time
The N/A had one drain plug and one fill plug, which also served as the check plug.
The TII had two drain plugs, one fill plug, and one check plug. You are to fill the at the fill plug until it starts coming out the check plug.
The procedure can be found in the FSM, found here:
www.iluvmyrx7.com
All that you will need to do is get under the car while it is jacked up and level, and remove the check plug and let any fluid pour out.
Old Jan 9, 2004 | 06:59 AM
SureShot's Avatar
I had a few spare minutes
Here is a clip from FSM.
The link to a mirror copy of the manuals is in my sig below.
Old Jan 9, 2004 | 11:53 AM
Jester's Avatar
www.iluvmyrx7.com
Thanks guys, I didn't know you'd take the time to check out my profile, . Sorry, I ment to include the info in the first post but I forgot. Thanks again!
Old Jan 9, 2004 | 09:30 PM
I am able to read the minds of RX-7 owners thousands miles away!
Plus I checked your profile just to be sure.
Yes it makes a difference. As you can see from the pic from the FSM above the procedure is quite different.
MILOS7
Oct 9, 2015 02:19 AM
LongDuck
Oct 7, 2015 08:12 PM
rxlevi7
Sep 26, 2015 07:28 AM
