Haltech PWM Outputs
Old Jan 7, 2004 | 09:20 AM
MOSTIN's Avatar
PWM Outputs
Why is my PWM out puts not working on my E6k? Doy I have to activate somthing?
Old Jan 7, 2004 | 08:38 PM
LTProject's Avatar
i think you have to go in and turn on which ever one you have hooked up. im new at this but ive got my fan on a pwm and i had to activate it and set the parameters for operation. i think its over by setup or options.
Old Jan 11, 2004 | 08:52 AM
MOSTIN's Avatar
I did all that and still nothing. What could be the easiest way of testing the outputs? I know the output attaches to ground when activated.
Old Jan 11, 2004 | 09:16 PM
LTProject's Avatar
i just used one wire off of the haltech harness, then i used a 4 prong relay(standard) and you have the haltech connected to the controlling side of the relay. ill give you the exact wiring tomorrow when i see my car again. What are you trying to run through the pwm?
Kind Regards
mike
Old Jan 11, 2004 | 11:58 PM
crispeed's Avatar
'Tuna'
Be careful when driving high high amp draw applications like fans etc. with the pwm drivers. It's mandatory to use relays. They burn out very easily without relays.
Old Jan 13, 2004 | 07:44 AM
LTProject's Avatar
Ok, i used the violet/white wire to control the 4 prong relay. If you get a relay it will have a diagram on it, use the haltech wire to close the relay, make sure that the high current is flowing through the relay and not the haltech. My harness is all sealed up but i think i had 2 powers and 1 ground then the wire from the haltech, theres your 4 wires. i just got the relay from a local parts house and they had a connector there as well.
Kind Regards
mike
Old Jan 16, 2004 | 11:34 AM
MOSTIN's Avatar
I am trying to run a shift ligt that dont draw that much amps, and if i am running anything else I will use a relay I am up to speed on how to wire the relay but I am not getting any indication from the haltech as to any of the PWM going to ground
Hey Crispeed I just spoke to pual at SFP to have scott to send me a diagram of an electronic boost controller that has an electronic soleniod I need to know which air line coming from the pressure side of turbo goes to the what part of the soleniod or on which port of the wastegate.
Anybody can chip in please
24seven_dada
20
Nov 10, 2018 12:03 PM
gfd263
Megasquirt Forum
Aug 28, 2016 08:58 PM
frijol
Microtech
Sep 23, 2015 12:51 PM
befarrer
Sep 22, 2015 09:33 AM
ZacMan
Sep 19, 2015 09:20 PM
