Headlight Cover Intake
Old Jan 6, 2004 | 12:07 PM
DoriSPL's Avatar
Question Headlight Cover Intake
Does anyone know where I can get one of these cheaper? Click Here
Old Jan 6, 2004 | 12:16 PM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
They are worthless. Make yourself a true CAI like ours or checkpoint's and you will gain more power. Check th epic in my sig for the link to my forum in it you can find pics of our intake design.
Santiago
Old Jan 6, 2004 | 12:18 PM
NCRX791's Avatar
oh yess....
www.corksport.com go and look under Other....you will see it like half way down the page....its only 90 bucks.....not bad at all......
Old Jan 6, 2004 | 12:42 PM
YearsOfDecay's Avatar
Locust of the apocalypse
From: Directly above the center of the earth (York, PA)
I made mine... Took about a day and it works great... Intake air temps decreased dramatically after the headlight cover was installed. Two things you must do to make it work however 1) you must remove the rubber flap attached to the hood that sits behind the headlight and you must also construct a cool air box that seals the intake off from the engine.
For the headlight cover…. I took a dremel tool and cut a slit across the middle of the headlight cover. Then, I used a ball-pine hammer and a stool with a bean cushion and beat the rear part of the slit up and the front part down to make a scoop. I got the metal as smooth as possible with the hammers and then used bondo to fill it in and round the edges off. I then primered it, painted it and clear-coated it. My car is black so matching the paint was not a problem. People ask me all the time where they can get one.. it looks really good.
For the cold air box, there are many designs out there, but basically I made a three sided plate with a hole in it for the MAF to bolt to, and used one of the MAF adapters for a K&N filter on the inside which bolts through the back plate onto the MAF. The top of the back plate and the side plates have 2” foam glued to them to seal up with the hood. (the box consists of a back plate that uses the old air box mounting points, a side plate which runs from right beside the radiator and makes a right angle with the back plate, and a bottom piece that blocks off any air from coming in from the flat area below were the stock air box sat.)
After these mods, I actually got and average of .35 seconds at the track over just removing the stock Air Box on my GTU.
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
