Are flywheels interchangable
Old Oct 14, 2001 | 06:17 PM
Rotorific's Avatar
I dont know a damn thing
Can I swap a Turbo2 flywheel on an NA or vica versa if i get the corresponding drivetrain. I really need to put an NA flywheel on a T2 block cause i dont have the T2 drivetrain. - Gabe
Old Oct 14, 2001 | 09:54 PM
Six Rotors's Avatar
Yes,if it is from the same year(more or less).So an 86-88 N/A MT flywheel will fit on an 87-88 TII motor.Similarly 89-91 N/A flywheel is OK on a 89-91 TII.
Of course the bolt pattern is the same on all,but the counter weight is different as noted above.
Old Oct 14, 2001 | 10:47 PM
Rotorific's Avatar
what can i do about the counterweight problem.
Old Oct 14, 2001 | 11:27 PM
Icemark's Avatar
the flywheels are different between the NA and T2.
The T2 flywheel is a larger diameter and is heavier.
The NA flywheel will bolt on however, but you'll need to use the NA bell housing, clutch, starter, and tranny.
Old Oct 15, 2001 | 08:22 AM
im using a 86' na flywheel on a 91' turbo block.. ill effects?
dunno blew my engine a week in..
Old Oct 15, 2001 | 09:33 AM
HAILERS's Avatar
HAILERS
Read this page from Mazdatrix http://www.mazdatrix.com/b5.htm I wrote a post just a few minutes ago. In other words there seem to be limitations as to the combination.
Old Oct 15, 2001 | 11:43 AM
HAILERS's Avatar
HAILERS
FOXX, The way I read http://www.mazdatrix.com/b5.htm your combination would violate their rule because your rotors, 86 vs 91. Might read the url and see what you think.
Old Oct 15, 2001 | 11:55 PM
Rotorific's Avatar
Ok let me clear things up I have an 86 base with corresponding drivetrain i have an 87 t2 block that has been ported and is used as a regular NA motor, I dont have the t2 drivetrain or needed stuff so i want to switch the flywheels and use my NA drivetrain. What issues should i worry about. -Gabe
Old Oct 16, 2001 | 12:03 PM
Evil Aviator's Avatar
Rotorhead
What kind of rotors are in the TII block?
Old Oct 16, 2001 | 01:34 PM
Rotorific's Avatar
I dont know what rotors are in it I pulled it out of a red 87 gxl. Ive posted before about how to find out what rotors are in the block and etc. but to no help. Now i dont care i just want to switch flywheels and worry about drivetrain later. - Gabe
LongDuck
Oct 7, 2015 08:12 PM
