Sponsored by: CARiD
HELP ?injectors?
Old Jan 5, 2004 | 05:29 PM
jl_rotary's Avatar
HELP ?injectors?
i am looking to buy a turbo2 that has a problem cutting out around 3500 rpms. when you drive nice and easy it drives fine, as soon as you give it 50% throttle it cuts out. which made me to believe the secondary injectors aren t working properly. does anyone have some solution to the problem or any helpful ideas. of course the first step would to make sure the injectors are plugged in properly, but i have no ideas after that. any suggestions would be greatly appreciated. thanks.
Old Jan 6, 2004 | 10:57 PM
black_sunshine's Avatar
If you mean that it totally dies when you give it more than half throttle, it means it needs a new ECU. I had an 86 base that did that; it'd rev fine, but once you gave it more than 50% throttle, it'd die; you could stomp on it at idle and it would die. You could rev it up to 6k rpm, give it 50% and it would die. Of course to kill it totally, I had to keep the accelerator depressed. I took the ECU apart and it was totally fried inside (burnt blue resistors and a scorched PCB under them).
If it's just hesitating really badly, plan on doing a complete grounding job as well as a fuel pump re-wire and replacing all the vacuum hoses. To test the injectors, swap them (primaries and secondaries). To see if the secondaries are turning on, either use a multimeter that tells duty cycle (DC) or just hook a regular multimeter and look for a voltage increase. Aside from that, test all the sensors/electrical devices (coils, CAS, BACV, AWS, ect..), and check fuel flow/pressure.
Old Jan 7, 2004 | 08:48 AM
jl_rotary's Avatar
thanks for the suggestion.
what is all involved with rewiring the grounding? what ground wires are you refering to?
Old Jan 9, 2004 | 05:25 AM
Doing a "ground job" is pretty easy. If you have a decent soldering iron, flux (makes copper/aluminum "sticky") or solder with flux (most of it is), then you'll be able to do this. Read this thread: https://www.rx7club.com/showthread.p...hreadid=179899
As some pointers, Don't get frightened by the #'s for the pins on the ECU. Really, just all the wires that are already bundled together about 6" up the harness (the one with 2 plugs) need to be grounded. I HIGHLY suggest you get pin 2C. Throw plenty of solder on the factory "crimp" connection(s). If you don't have a nice pair of crimpers, solder the wires inside the ring connectors. They're grounds, so if the plastic melts a little, it doesn't matter. Make sure to tape everything (the actual solder joints) nicely when you're done.
I noticed, however, that when I had both the ECU and the Boost sensor re-grounded that it somehow managed to make my problem worse. How, I still don't know (the ground was still reading 0ohms with or without the tertiary ground).
Best rule when doing something that seems hard: Keep it simple.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
connerfd3s
Sep 19, 2015 05:58 PM
