fuel cut switch??
Old Jan 4, 2004 | 11:31 PM
avoid's Avatar
fuel cut switch??
Scroll down on link wouldn't hurt the car by shutting off the fuel pump with the car still on Link Has anyone done this mod??
Old Jan 4, 2004 | 11:34 PM
88IntegraLS's Avatar
Displacement > Boost
There is a thread in the 2nd gen archives called "bits of FC wisdom" which has info on how to install the fuel cut switch. I followed the instructions in that thread to install mine and have had no problems, and MUCH easier unflooding on the rare occasions that the engine doesn't catch on the first crank.
As far as cutting the fuel to kill the engine, I doubt that would hurt anything on and N/A engine; it is standard practice with airplanes to shut off the engines by cutting the fuel before the spark. It might help if your car has leaky fuel injectors, but I see no other benefit to it. I wouldn't shut off the engine this way if the car is turbocharged.
Old Jan 4, 2004 | 11:40 PM
Sideways7's Avatar
I did that on my car before I got a rebuild. It pretty much took care of the flooding problems and made it much easier to unflood if it did. I don't know of any adverse effects on an NA car, but Im not for sure.
Russ's Avatar
https://www.rx7club.com/showthread.p...highlight=bits
link for you
astrum
24
Nov 15, 2017 08:44 AM
alphawolff
Nov 17, 2015 05:57 PM
armans
Aug 15, 2015 09:08 PM
