Sponsored by: CARiD
gas in oil
Old Jan 4, 2004 | 10:33 PM
riffraff's Avatar
smog nazi destroyer
Angry gas in oil
real simple, what are the ways that gas can get into your oil?
Old Jan 5, 2004 | 03:00 AM
1984special's Avatar
So little time and money
Flooding your motor, which I think is more common on the older cars. Gas in oil is bad, as the oil doesn't seal the chambers very well so you get bad starting compression.
Old Jan 5, 2004 | 11:25 AM
David Beale's Avatar
It's normal for our cars. If the car runs rich, the injectors leak, or you flood it. The fuel runs past the rotor seals into the oil cavity in the centre of the rotor. The seals are good at stopping oil but gas just goes right under them.
It's why we change the oil more often than piston engined cars.
Old Jan 5, 2004 | 10:58 PM
riffraff's Avatar
smog nazi destroyer
i am so glad to hear that.. i was worried that i had blown a seal in my new motor.
i flooded my engine a few weeks ago, and it is running rich, so i guess that explains that
Old Jan 5, 2004 | 11:45 PM
SNracing's Avatar
aka KingDrunk
its better to run rich than lean though
Old Jan 6, 2004 | 06:10 PM
riffraff's Avatar
smog nazi destroyer
that is why i am having the problem. i set the carb up to run rich for the motor break in, and until i can get it onto a dyno. only problem is that i made it a little richer than needed.. i am getting somewhere around 8-9 mpg.
Old Jan 8, 2004 | 04:56 AM
Jeff20B's Avatar
Lapping = Fapping
Rotaries put oil in there gas. Piston engines pollute their oil with all sorts of crap.
Microtech
30
Apr 23, 2016 06:37 PM
R7rexy
19
Sep 2, 2015 10:24 AM
smikels
Aug 18, 2015 01:26 PM
