Sponsored by: CARiD
Electrical Help Sought
Old Jan 1, 2004 | 05:07 PM
jdemmie's Avatar
I can turn the ignition switch to off and pull the key, yet the car remains running. The switch tests ok. Any thoughts or experiences?
Old Jan 1, 2004 | 07:22 PM
black_sunshine's Avatar
Check the main relay. It could be sticky. It's located on the driver's side of the engine bay, right next to the trailing coils.
Old Jan 1, 2004 | 08:02 PM
chairchild's Avatar
50mpg - oooooh yeah!
Does it still run like normal? Or does it just splutter for a bit?
If it splutters, that's called run-on, but I've never heard of it happening on a rotary before!! Lob some carbon-removing stuff into your tank to stop this. If it just runs perfectly normal though, then it's electrical
Old Jan 2, 2004 | 05:29 PM
jdemmie's Avatar
I'm heading in the direction of a stuck relay .... if that's possible. Anyhow, that's my next plan, so thanks for the direction.
As far as run-on, this is not. If it weren't for the steering lock she head right down the road without the key.
Jack
Old Jan 2, 2004 | 05:39 PM
chairchild's Avatar
Cut the cover clips off the relay casing, and dunk it in some white spirit to clean it. They can sometimes oxidise or get a carbon build-up inside of them, the bigger the relay, the bigger the problem
WANKfactor
Sep 29, 2015 01:14 PM
