Hmm Sqeuking, what could it be.
Old Dec 31, 2003 | 08:06 PM
BigJim's Avatar
trainwreck
Well ive taken off of all my belts so that no pulleys are spinning, still something is squaking . It pulses and is pretty high pitched, it sounds like its comming from the front of the engine, but my dad thinks maybe something witht he clutch, anyone have any ideas?
Old Dec 31, 2003 | 08:09 PM
wwilliam54's Avatar
it WILL run
i still think it might be the oil pump
did you ever take the front cover off
it might be the front cover bearing
Old Dec 31, 2003 | 08:10 PM
BigJim's Avatar
trainwreck
Front cover? How hard is it, and where and what is it.
Old Dec 31, 2003 | 08:18 PM
wwilliam54's Avatar
it WILL run
its the big grey thing on the front of the engine
is the sound coming from it?
Old Dec 31, 2003 | 08:19 PM
BigJim's Avatar
trainwreck
its comming from that general area
Old Dec 31, 2003 | 08:20 PM
BigJim's Avatar
trainwreck
i thought it was somethign to do with the intake because it sounds like its comming from right htere so its prolly the front cover bearing
Old Dec 31, 2003 | 08:22 PM
wwilliam54's Avatar
it WILL run
it would be worth a check
someone who has put one on recently will chime in and help im sure
BigJim's Avatar
trainwreck
Ok thankya, ill just sit and wait for results now
Old Dec 31, 2003 | 08:23 PM
coldy13's Avatar
Yeah, shutup kid.
If it's not that it could be the clutch pilot bearing, mine sounds a lot like a belt squeaking.
Old Dec 31, 2003 | 08:24 PM
BigJim's Avatar
trainwreck
crap, we just changed my clutch and put on a newer pilot bearing. If its that im pissed cause its alot of work takin out a trany
Old Dec 31, 2003 | 08:26 PM
BigJim's Avatar
trainwreck
any way to tell if it is? will pushiing iin and out clutch or putting it in gear and engaging(cars on jackstands) change hte squeking so i can see if thats it?
coldy13's Avatar
Yeah, shutup kid.
Yeah, I did it 4 times in a month getting my turbo running right. Many clutch and oil leak problems...
ChanBagz
Sep 17, 2015 03:36 PM
