I Am Lost
Old Dec 30, 2003 | 09:25 PM
Chamele03's Avatar
I Am Lost
I have no idea whats goin on inside this little '79 i have;
A couple of weeks ago i had it running and it would idel, i even drove, then had Dizzy securing prob. fixed that, now i cant even get the car to stay running with my foot on the gas. i didnt change anything but the timming, than when i got tired of trying different locations, i got onto the idler screw, ( previouse problem on this carb). The car will fire up every.....30th try or so it seems but will only run for a moment or 2 then die. I dont see how it could be fuel since nothing had been changed from its prior running state, and i even tried putting a better cap on the dizzy. im not at the shadetree mach. point of throwin random things at it then seein if it will work.
any direction anyone can comeup with will be very appreciated
Old Dec 30, 2003 | 09:38 PM
wwilliam54's Avatar
it WILL run
plugs are probly fouled
Old Dec 30, 2003 | 10:44 PM
Knifeparty's Avatar
Yeah, could be. Try replacing your spark plugs and spark plug wires. If you are still having problems, try replacing the dist. cap as well, might help!
Good luck
Old Dec 30, 2003 | 10:46 PM
LongDuck's Avatar
84SE-EGI helpy-helperton
If the only thing you changed was the timing, I would go back and doublecheck your work on that. You stated that you had it idleing before and it was driveable. Whatever happened when you fixed the 'dizzy securing problem' may have resurfaced and your timing is off just enough to not keep it running.
Also, as William pointed out, pull your plugs and see what they look like. If wet with gasoline, you probably have timing set too late to get a spark while you're at max compression. Ideally, you'll need some advance to ensure that it's sparking a mixture that will ignite properly and spin the rotor to the exhaust phase.
If nothing else has changed, I'd go back to where you started. HTH,
Old Dec 30, 2003 | 11:27 PM
rxtasy3's Avatar
Bring the engine up to TDC and make sure the dizzy is in right, u know, lined up with the mark, then go from there. I'm assuming u took it out to fix the securing problem?
Old Dec 31, 2003 | 04:27 PM
Chamele03's Avatar
I think its my plugs also, the leading ones are black; i tryed to get new ones, but AZ doesnt have them and neither does Orielys, im just bummed,
thanls for the "point in some direction"
Old Dec 31, 2003 | 09:31 PM
Rx7carl's Avatar
Airflow is my life
Clean them and try again.
Old Dec 31, 2003 | 10:08 PM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
"dizzy securing problem"= the nut fell off
Old Dec 31, 2003 | 10:15 PM
alien_rx7's Avatar
Interstate Chop Shop CEO
If by AZ you mean AutoZone, the one here has them. In fact they only have two choices, Champions or NGK. Of course I bought the NGK's If they don't have them in stock, they can order them and it only takes a day or two.
Old Jan 2, 2004 | 05:35 PM
Chamele03's Avatar
ok, I had to order a set of NGK's from Orielys; got them today and they arent like the ones i have in the car now, they are shorter and have prongs,( this is like the plugs in all my other engines) the ones i have in the car right now are flat on the top and marked T & L witch i assume is trailing and leading, i tried threading the shorter ones in but they just keep going into the bllock and my socket wont go past the lit on the block, will this cause problems? im so afraid ill messs this car up,
I just wanna drive it so bad
Old Jan 2, 2004 | 05:39 PM
wwilliam54's Avatar
it WILL run
yo need to grind down a socket so itll go past the lip
Old Jan 2, 2004 | 05:43 PM
Chamele03's Avatar
I have pics of the plugs but they are too big;
wwilliam54, the ones that are in my other engine dont go all the way in, do i have to thread them all of the way into the block?
by the way the ones in my car are NGK BUR7EQ
the ones i bought are NGK BR7ET
Old Jan 2, 2004 | 05:49 PM
wwilliam54's Avatar
it WILL run
some plugs have the socket high, some low
the new ones are low, but they still need to be threaded all the way in
get a socket and grind down the outside so itll fit in between the plug and the lip
Old Jan 2, 2004 | 06:35 PM
Chamele03's Avatar
ok, I took the new plugs back, and turns out when they actually pay attention to what you say, they might just have what u actually need in stock. NGK BUR7EQ and NGK BUR9EQ spark plugs are flat on the top and have a longer sleeve, to get past the lip that is apparently on some year 12a? its not on a '79 engine ill tell you that much. and doesnt seem to be on what i was told was an '81 engine either. they dont have these plugs under any sertain application, event thought the 7s are marke T and the 9s are marked L and the box has "(something foreing) RE" on it, but im gunna go try these and does anyone know what year 12a I have in my car because i have no clue.
Old Jan 2, 2004 | 07:39 PM
wwilliam54's Avatar
it WILL run
I thougt all year 12a's had that lip
Old Jan 2, 2004 | 07:48 PM
faye x7's Avatar
brilliantly stupid
This is what I use: BR8EQ-14
They fit fine and car runs fine and they cost me about $21 for all four plugs.
Old Jan 2, 2004 | 07:50 PM
wwilliam54's Avatar
it WILL run
same here
im probly switching to autolights tho
rahter change em every oil change
Old Jan 2, 2004 | 10:52 PM
alien_rx7's Avatar
That looks like the kind I'm running also. They're the ones listed for the car at AutoZone and fit without the need for any special socket.
I think it was the 79 and 80 engines that did not have the spark plug boss around the hole. Mazda later decided to add it to keep people from using the wrong spark plugs since if you do manage to use one that is threads in too far the electrodes can come into contact with rotor and something gets ruined. 81-85 have the boss.
Old Jan 3, 2004 | 12:08 PM
Chamele03's Avatar
ok these are what was in, and are now in the car
Old Jan 3, 2004 | 12:10 PM
Chamele03's Avatar
here it is next to the spark plugs i pulled out of my other engine which ar the same as the ones i first got from orielys
Old Jan 3, 2004 | 12:23 PM
Rotor13B's Avatar
Wassup!!
The first one is a 2nd gen plug.
Old Jan 3, 2004 | 05:05 PM
alien_rx7's Avatar
Yup, first one is not the correct one for the FB but the second on looks too short also. If you mix the first one's long body with the second one's end (four prongs) then you have the one that I am running which is probably the same as the one shown above (BR8...)
I'll pull mine just to make sure and repost tomorrow (already dark here).
Old Jan 3, 2004 | 07:44 PM
rhinor61's Avatar
Wrong plugs.... Maybe you should say they were not the manufacture recommended spark plug for his year of car.
Why, cause I run 3rd generation trailing plugs on my leading side, maybe not the ideal plug for putting around in the city. But when you are out doing a track day they sure like to REV IT UP.............
1981-85 (12A) Both BR8EQ-14 is the correct factory recommended spark plug.
John
Old Jan 3, 2004 | 10:25 PM
1984se's Avatar
Ryan
Those are NGK's Stock#- 3559 Leading
5483 Trailing
Use the NGK stock #2329 - (BR8EQ14)
You can use these plugs for 79-85 12a & 13b.
-Ryan
Old Jan 4, 2004 | 03:29 PM
alien_rx7's Avatar
Ok, pulled my plugs. I actually don't have NGK in there like I had thought. I have the Denso W25EDR14's installed. They still look like the BR8's though and they run great with no problems and fit without the need of any special sockets
Coochas
44
Nov 5, 2019 11:08 PM
Coochas
Oct 3, 2015 04:49 AM
TrboMike
NE RX-7 Forum
Sep 28, 2015 09:40 PM
Devon Murray
Sep 25, 2015 09:41 AM
