pls read if u have a weber 48 IDA
Old Dec 30, 2003 | 08:13 AM
timmya2's Avatar
Hey..
weber is great..
but sumthing bad happened today..
this crappy slow car.. well i was at the stop lights..
go signall..
car bogs down.. crappy small car flys away probably laughing at me
took me ages for me to get goin..
everytime i put it on D (i got an auto) it would die..
until my third attempt it worked.. and finally i drove off..
wat gives?
Old Dec 30, 2003 | 10:39 AM
CHEF_EG_1's Avatar
Rollin' coal and 53mpg!
You REALLY can't just dump it... the Weber 48IDA is a carb where you need to feather it to get it opened up, THEN you can maul on it. It doesn't really start flowing really well until above 3500...
Old Dec 30, 2003 | 12:38 PM
427Aggie's Avatar
I don't know if its the same on the 7's with a single as it is with 4 but you get the same problem if you are flooding it...There is a bypass valve in the float chamber of the 48IDA that you can change to 50 or 55 and that takes care of alot of the stumbling problems with these carbs. My Cobra was terrible till I changed these and I can mash it to the floor from the start I don't have to ease into it.
We will see if the same holds true when I get the 7 running again and ready to race.
Matt
Old Dec 30, 2003 | 04:52 PM
1rx7owner's Avatar
Lifes a garden dig it.
I got the 48ida and I can give it hell whenever i want. No bogging down any time. I only have the problem of a little stumbling at crusing speed.
Old Dec 30, 2003 | 05:14 PM
fitzwarryne's Avatar
It may end up as a problem matching the IDA with an automatic. You just can't feed in the clutch.
I presume you are a two foot driver, so left hard on the brake and keep the revs up with the right. When the lights change, hard right and off left.
Old Dec 30, 2003 | 06:48 PM
81Rex6port13b's Avatar
I Push My Car Real Fast!
what do you have the 48 on? not a stock 12a i hope
Old Dec 30, 2003 | 07:10 PM
timmya2's Avatar
lol yep stock 12a
Old Dec 30, 2003 | 07:13 PM
with a 48 when you gas it hard you are prolly flooding it. so it will bog out.
48 is big for a 12a.
Old Dec 30, 2003 | 07:42 PM
heb09's Avatar
go a holley 465
Old Dec 30, 2003 | 08:03 PM
timmya2's Avatar
nah..
i think i just need to tune it right..
its only overkill in terms of money..
but u wont be losing performance
