dankus inspired intake :D
Old Dec 28, 2003 | 06:53 PM
Gregs's Avatar
Talking dankus inspired intake :D
Hey guys, i just got back from the junkyard, and i was like OH ****, im gonna make me a ghetto intake! turns out i found parts and its not so ghetto...
im not finished and im going to be running a cone filter off the intake pipe, but im not sure if i want to mount the filter in front yet... time will tell
here are the pics
props goes out to dankus rotary
Old Dec 28, 2003 | 06:55 PM
Gregs's Avatar
oh FYI, the "carb hat" came off an early 90's taurus and the pipe came off a mid 90's escort with the sefi engine or whatever..
-greg
Old Dec 28, 2003 | 07:00 PM
wwilliam54's Avatar
it WILL run
1337
Old Dec 28, 2003 | 07:08 PM
rotarydankus again's Avatar
contributions gladly excepted, kidding, a tell me friend how much have you spent so far ?
Old Dec 28, 2003 | 07:11 PM
Gregs's Avatar
so far i have only spent 4 dollars
dankus ur the man, im gonna try and find more junkyard ideas, maybey u can start a website with junkyard first gen performance mods
Old Dec 28, 2003 | 07:28 PM
ioTus's Avatar
'84 5-letter
ya dude that hat looks tyte!!! get a hole drilled int he top, screw her down, tell me how it fits!!!!!
Old Dec 28, 2003 | 07:33 PM
DANKUS SALVAGE YARD RACING! wait is that the discovery channel calling? hold on a sec , hello? yes this is dankus ? whatt ? all hondas are salvage yard built? thanks , um , bye ! seriously im doing my enging compartment up and i found some neat relay boxes and a maxi fuse strip to replace the week *** fuse links , when its done ill get more pics up
Old Dec 28, 2003 | 07:34 PM
Gregs's Avatar
yo dankus, this is just a crazy thought, but do you think a little k&n oil breather filter on the hole on the side of the "carb hat" would do anything? or should i just plug it off,
just a random idea
never hurts to ask
-greg
Old Dec 28, 2003 | 09:11 PM
Metallic_rock's Avatar
Ride 'n Style
plug it.
Old Dec 29, 2003 | 11:17 PM
you know now that you mention it thats a good idea, ive experienced carb venturi freeze up a couple of times , it happens if temps below 37 or so but still above freezing, 100 percent humidity was the culprit, fortunately letting it set for just a couple minutes let engine heat build back through carb and shes good to go, maybe that little filter would allow a little engine heat back into air stream , I even got wone on the intake pipe to airpump , which i cut the belt to, i used a red urethanne bushing to plug mine
Old Dec 29, 2003 | 11:37 PM
Gregs's Avatar
how did you connect the carb hat to the carb?
a long bolt?
-greg
Old Dec 30, 2003 | 12:39 AM
u aint gonna like this but i had a used carb offn my spARE eng , i chopped the bolt down on it and hose clamped it to the old one so i could reinstall old cleaner in a pinch, gonna do some thing differrent soon cause i can hear i now from the peanut gallery , maan what if one of them there clamps gets down in motah?
