Fuel Pump Question ??
Old Dec 26, 2003 | 10:57 PM
RE13REW's Avatar
Red face Fuel Pump Question ??
Should Walbro fuel pump 255 handle the the ported engine and T78 with 18psi or up boost ???
Old Dec 26, 2003 | 11:14 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
I don't think it's very safe... I'd at least run duals in the tank..
What are the rest of the fuel mods? You do have some I hope...
Old Dec 26, 2003 | 11:48 PM
jspecracer7's Avatar
1JZ powered
Re: Fuel Pump Question ??
Doubt it will work at that PSI
Old Dec 27, 2003 | 11:04 PM
RE13REW's Avatar
I will install a upgraded pressure regulator, injectors, and fuel rack. I don't know what you mean install dual in tank ?? you mean two fuel pump in tank ??
injectors will be 850cc & 1200cc or 1600cc
Old Dec 27, 2003 | 11:09 PM
Nameless's Avatar
Yep stick 2 walbros in there... I think Dragon runs this setup.
Old Dec 27, 2003 | 11:13 PM
mmonaco's Avatar
Part out my Car
Im the one with the dual walbros 255 in parallel! I have some pics if you want to see the setup
Marc
Old Dec 27, 2003 | 11:32 PM
1JZ powered
The whole Japan forum damn near runs this setup....myself included.
Old Dec 28, 2003 | 12:51 AM
fd3virgin's Avatar
get a supra pump. 165 from suprakid.
Old Dec 28, 2003 | 11:26 AM
BBK makes an awesome in-tank fuel pump for the RX7. It runs about $160 If that isn't enougf Barry Grant fuel pump can support 2000hp at over 60psi. Runs about $470
Old Dec 28, 2003 | 04:48 PM
1JZ powered
Supra pumps a great alternative to the walboro, but a bit pricey. Also, it needs 12+ Volts to work right on the FD.
Old Dec 28, 2003 | 05:17 PM
rx7raca's Avatar
wHiTe kNiGhT
i think the nippondenso is good. ive heard good things about it, but have never ran it myself. what do you guys think about it?
also ive heard that running 2 stock pumps isnt to good. i forget the reason though.
Old Dec 29, 2003 | 12:14 AM
I would go for pics.
Old Dec 29, 2003 | 09:38 AM
jdhuegel1's Avatar
Glug Glug Glug Burp
Of what? A dual pump setup?
Old Dec 29, 2003 | 10:45 AM
mmonaco said he had some of the this setup.
Old Dec 29, 2003 | 11:58 AM
DCrosby's Avatar
No it's not Turbo'd
What about a Cosmo pump, if it can handle 3 rotors why shouldn't it be able to handle 18 PSI / 1600's ?? Just a thught no real basis for this comment...
Old Dec 29, 2003 | 12:32 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
My bad! I'm just a hair stupid sometimes...
Old Dec 29, 2003 | 04:16 PM
With,
-GReddy Trust cat-back
-GReddy Airnix intake
-Blitz SMIC
-aftermarket Downpipe
-MP
-PFC
-Fluidyne
-Walbro 255
First: What size injectors should I get, and what is a safe PSI to run at this stage? Also, what whp do you think I would be close too?
Second: Should I go with the MP or a High Flow Cat from Pettit? I thought the MP should connect to a Cat? Or is the Pettit a separate bolt-on?
Please excuse me about tagging on this post. Just thought that sense we were all on the fuel system... =)
Old Dec 29, 2003 | 08:25 PM
1JZ powered
I've run this setup before. Two stock FD pumps thru two individual lines forward, one fueling the primary rail, the other fueling the secondary rail, then "Y" into an aeromotive FPR. with a single line back as a return.
With this setup, you'll need to run 12V constant to the pumps. It will work fine with a T-04S or similar turbo at appx. 15 psi, but I wouldn't boost higher or put anything bigger on without upgrading the pumps.
Rotospectre
Mar 28, 2018 03:33 PM
alphawolff
Nov 17, 2015 05:57 PM
