Intercooler and BOV help
Old Dec 23, 2003 | 03:34 PM
Kitsune's Avatar
I am planning to buy the Blitz FMIC and the Blitz BOV plus I was thinking of replacing the stock elbow to the with either the Greddy elbow or the Greddy elbow with flang .
My question is that if I get the Blitz kit where does the bov located on the blitz fmic? Also if I get the Blitz fmic and bov kit and also I add the greddy elbow with flange can I have a dual bov?
Or if I just the the blitz fmic and the greddy elbow and use their built in flange would be better? I need help!!
Mike
Old Dec 23, 2003 | 03:44 PM
FD3RotorTurbo's Avatar
FD3Rotor
i dont think that the blitz fmic has anywhere with a flange (correct me if i am wrong) so you would have to get the GReddy elbow w/ flange. or else custom your own in somewhere. but if i where you i would get the greddy w/ flange. because its the closest to the throttel body
Old Dec 23, 2003 | 03:53 PM
180sx-x's Avatar
Zoom-ing Goon.
i have a blitz BOV on my car. but i have the stock SMIC. if you get the blitz kit, it'll replace the stock bov on the y-pipe. here, check out where my bov is at. its on the second page> http://www.cardomain.com/memberpage/483371
Old Dec 23, 2003 | 03:55 PM
180sx-x's Avatar
Zoom-ing Goon.
oh, BTW, good luck getting the BOV 2 work properly if u still have the stock twins. It'll work fine, just getting it at the right tightness might be a little time consuming.
Old Dec 23, 2003 | 04:55 PM
Kitsune's Avatar
Does it make a difference if its near the throttle body?
So how do I do a dual BOV?
Mike
Old Dec 23, 2003 | 05:48 PM
FD3Rotor
Mike
closer to the throttle body the better... thats where the back pressure starts. when the butterflys close the air starts to puch back and if its closer then the pressure gets out sooner, stoping any air from gettin back into your turbo(s)
and why do you want 2 bov's?
Old Dec 23, 2003 | 08:30 PM
Kitsune's Avatar
I heard if you are running high boost like 20+ psi its better to have 2 bov's, is this true?
Mike
Old Dec 23, 2003 | 11:44 PM
FD3Rotor
Mike
i have never heard of this... if you are running higher boost then you get a different spring for your BOV that can take higher boost.
Old Dec 24, 2003 | 12:48 AM
spoolin1012's Avatar
I have a question... If I were to weld a universal bov, how would I plug up the stock bov, or do you just run both.
ls1swap
Jun 3, 2024 03:25 PM
