fuses are blowing up
Old Dec 22, 2003 | 12:10 AM
i_heart_rx7s's Avatar
Question fuses are blowing up
I've just recently installed a new pioneer deck and hooked everything back up, but now my dash lights are working. I found out it was the fuse so I replaced it, and replaced it, and replaced it. As soon as I turn the ignition the fuse goes!
HELP!
Thanks
Old Dec 22, 2003 | 06:21 AM
user 9348703's Avatar
wires crossed, I dont think grounding out will do that, but time to pull it out again and re-check your work.
Old Dec 22, 2003 | 06:48 AM
wires crossed? I didn't change any of the wires relating to the dash... would other wires interfear with the dash ones?
Old Dec 22, 2003 | 10:43 AM
rxtasy3's Avatar
maybe it's something to do with illumination of the radio when the lights r on. Unplug all wiring to the radio and see if it still blows the fuse.
Old Dec 22, 2003 | 11:58 PM
I taped up some wires that i wasn't using because I thought they might be interfering (which I should of done in the first place) and the fuse no longer blows, but they dash lights aren't coming on. Did I blow the bulbs? or is something else the matter.
any suggestion will be appreciated. i have no clue what the problem is.
Old Dec 23, 2003 | 03:53 AM
check the relays...
Old Dec 23, 2003 | 08:56 AM
what is the relays? I'm a newbie
FC3S Timmy
16
Oct 3, 2015 01:08 AM
