cheap , fast, easy carb bonnet!!
Old Dec 19, 2003 | 11:51 PM
rotarydankus again's Avatar
Thumbs up cheap , fast, easy carb bonnet!!
after a good freind of mine donated a cold air intake to my project, ive been wandering around looking for some thing to use as a quick carb bonnet. i rent from a salvage yard so i new its a matter of time , tonite i found it, get this a FORD, gaaaack i know , powersteering pump resovior , plastic some black some tan, 85 and up on every car and truck they built, check out these pics and tell me what you think, another fine nickle and dime performance tip from DANKUS SALVAGE YARD RACING< wow maybe ill get to be on the discovery channnel , tre v
Old Dec 19, 2003 | 11:55 PM
heres another
Old Dec 20, 2003 | 12:02 AM
NanaimoRx-7's Avatar
So do you have the filter right out front in the grill?
Old Dec 20, 2003 | 12:13 AM
it ende up slitey right of smack center of the condenser, it looks tite from underneath ill get a pic tomorrow
Old Dec 20, 2003 | 05:56 AM
Rx7carl's Avatar
Airflow is my life
Very resourceful. How are you holding it down? Feel like sending it to me for some flow testing?
Old Dec 20, 2003 | 07:57 AM
Sterling's Avatar
Nikki-Modder Rex-Rodder
Great job! That's really great...I, too, applaud your resourcefulness. I like anything like that where someone looks for a recycleable part.
...lemme guess...you like "Junkyard Wars", too, like me.
Old Dec 20, 2003 | 08:28 AM
ray green's Avatar
Gone
When I was in college in Tuscon Arizona in 1972, I was fortunate to know and party with an older gentleman named Nathan who, it was claimed, held the patent for the pressurized cabin from work he did with Lockhead, which subsequently screwed him. Nathan drove around in a modifed VW bug that weighed less than 1000 pounds - in his retirement he liked to travel around the world and he preferred to take his car with him. To get the weight reduction, he replaced all the body sheet metal with aircraft aluminum, sat on the floor with a few cusions for a seat and replaced all the hydrolics with cables. Neatest of all was the carburator, which had been replaced with an aluminum coffee pot. I have no idea how this worked, I had a bug at the time but my mechanical knowledge was limited to changing the oil (the first time I did this, slightly enebriated, I neglected to put the drain plug back in before adding all the oil I had purchased for the job. But hey, I was 18 and more interested in girls than cars. Actually, now that I think about it, this is still true, but the gap has closed somewhat). Anyway, Trevor, your ingenuity reminds me of Nathan's genius, thanks for the tip and please forward instructions!
Ray
Old Dec 20, 2003 | 12:35 PM
FD Racer's Avatar
sold the FD...kept the FB
it looks pretty restrictive... how does it drive, any increase in power?
Old Dec 20, 2003 | 02:03 PM
Gregs's Avatar
*gets iin car, heads to the junkyard*
you said all 85 and up fords right?
Old Dec 20, 2003 | 02:16 PM
wwilliam54's Avatar
it WILL run
do you think it will hold up to any boost
Old Dec 20, 2003 | 03:06 PM
timmya2's Avatar
wow is that a nikki carb with a CAI? and u used the resovoir as the filter? does it fit exactly?
Old Dec 20, 2003 | 03:44 PM
Gregs's Avatar
silence
Old Dec 20, 2003 | 05:29 PM
Directfreak's Avatar
I am a Jeeper Now.
Originally posted by Gregs
silence
Equally Quiet.
Old Dec 20, 2003 | 05:30 PM
Gregs's Avatar
no the silence was for timmy because he was asking questions that were clearly stated in the original post lol
-greg
Old Dec 20, 2003 | 06:13 PM
Suparslinc's Avatar
It's Back!
Am I reading this right?
Old Dec 20, 2003 | 06:55 PM
Pedestrian X's Avatar
SpAz!
Was it soem sort of purcalator setup to handle boost?
Old Dec 20, 2003 | 10:35 PM
timmya2's Avatar
silence
Old Dec 20, 2003 | 10:39 PM
ok, i got 8 pics . Ill podt more if u want them. i think the car runs better, it definately sounds better, i plumbed a vac gauge onto tube nippl 6 '' from bonnet, to check for restriction, almost impeceptible needle move ment , less than 1.5''hg at WOT . so i pucned a 3/16 hole in stock filter housing lid rite to the carb side of filter, at WOT it was almost 3''hg. proof in pudding. i routed pipe through radiator ducting at upper corner pass, side. elbow then filter. see for urself, trev
Old Dec 20, 2003 | 10:41 PM
ere
Old Dec 20, 2003 | 10:44 PM
'ere
Old Dec 20, 2003 | 10:48 PM
**** , forgot pic, doh
Old Dec 20, 2003 | 10:52 PM
last 1
Old Dec 20, 2003 | 11:20 PM
Rx7carl's Avatar
Airflow is my life
Ahhhh thank you. Numbers. Yes the stock housing is very restrictive. Look at my airbox post. 1.5" of hg as your gauge says is still very restrictive. Thats equal to 20 or so inches of water column. No offense, but my mod flows the same as no filter/airbox at all.
Old Dec 20, 2003 | 11:28 PM
thats awesome carl, my only deal was the 6.00 dollar issue, went out and pulle the filter off the end of pipe and run it again, tthe needle twitched once at the application of wot , then settled back to the peg, seems to me a better flowing filter would be required, any suggs?
Old Dec 20, 2003 | 11:49 PM
Rx7carl's Avatar
Airflow is my life
Well definately better than stock, as youve shown. My numbers come from dry flowbench testing so theres no variables. Even 1.5"hg is wayyyyyyyy too high a restriction IMHO. Thats 20.3" water.
