GT40R Turbo Only?
Old Dec 13, 2003 | 03:03 PM
Fatty_FC3S's Avatar
GT40R Turbo Only?
Anyone happen to know how much the GT40R by itself would be? I know there are kits avaliable, but it would be easier and cheaper for me to just buy the turbo itself and build the rest of the stuff.
Any ideas on the price of this? Maybe close to the price of a GT35/40 ?
Old Dec 13, 2003 | 03:15 PM
allrotor93's Avatar
i looked into that but it isnt a good idea. aspec does a number of things to the gt40 for it to work with our cars. everything is custom down to the turbo.
Old Dec 13, 2003 | 04:25 PM
rotaryextreme's Avatar
Veteran: Navy
You will not want to just buy the turbo from any turbo shop. GT40R comes with a very weird turbine housing with a built-in non-flat v band flange. You will have to machine the flange flat to meet up with a 3.5" v band flange. Regular turbo shops can not do this for you. This has to be done with a CNC machine or you will have exhaust leak. We have done it already since we have the CNC machinist. If you want more info, email me at rotaryextreme@aol.com
Chuck Huang
Old Dec 13, 2003 | 08:27 PM
Carl Byck's Avatar
Mad Man
So Chuck, do you have a GT40R for sale? (pm please) I need a 4" Vband, can you do that? If you are in the business, what AR, and trim did you choose? Thanks, Carl
Couldn't you just get a Vband clamp from Garrett, rather than machining the housing?
Old Dec 13, 2003 | 08:41 PM
88fc3sw/HX83's Avatar
Carl, Cant you make up your mind on which turbo youre gonna run? I thought you were gonna run the T-66?
Old Dec 14, 2003 | 11:50 AM
Carl Byck's Avatar
Mad Man
I have a T66, but I may put it in my Supra, I will try the T66 in the RX for sure, but no I cannot make up my mind, just ask my wives
Old Dec 14, 2003 | 03:53 PM
Poweraxel's Avatar
as "allrotor" and "rotaryextreme" said the GT40R will not work just by itself..there needs to be some machining done and a special adaptor for the turbine flange, this is not done by the average "turbo" shop ... Sean at A-spec already takes care of that with the kits
Steve
Chuck Huang
Old Dec 14, 2003 | 03:57 PM
Poweraxel's Avatar
Nope.
Old Dec 14, 2003 | 09:05 PM
Fatty_FC3S's Avatar
Maybe i should clarify some things
I dont want to buy a whole kit with a manifold and wastgate and whatnot. If i must by the turbo from Aspec, i have no problem with that, im pretty open to any vendor at this point. I enjoy building my own parts and this is no exception. So i would need the turbo from them because its machined to work, is that correct? Then from there i can just build my downpipe, manifold etc? Maybe im missing something here, but i dont see why i would have to buy everything, only the machined turbo and Vband clamp....
Old Dec 14, 2003 | 09:52 PM
allrotor93's Avatar
i dont think they will sell you just the turbo. they go through too much work to make it work to just make a few dollars on a turbo sell.
Old Dec 15, 2003 | 08:25 AM
surfpac's Avatar
http://www.atpturbo.com/Merchant2/me...egory_Code=GRT
Old Dec 15, 2003 | 08:43 AM
allrotor93's Avatar
the flange on that turbo is all messed up. shawn form aspec was describing it to me.
Old Dec 15, 2003 | 10:17 AM
carx7's Avatar
Fatty, sent you a PM.
-Chris
Old Dec 15, 2003 | 10:35 AM
fcritch's Avatar
Is there a website for Aspec?
I'm looing at the GT turbos as well.
Thanks
Ritchie
Old Dec 15, 2003 | 10:37 AM
MeLoco's Avatar
There is but it is being updated so it is not going to show you any info on the GT series turbos But their # is 630.543.8890
www.a-spectuning.com
Old Dec 16, 2003 | 11:43 AM
rx7tt95's Avatar
Photo Diety
I'm sure ATP could "adjust" the turbine discharge given the fact they have a full machine shop.
Sean did mention some time back he had a few turbos for sale too, turbo only.
Old Dec 16, 2003 | 01:08 PM
Zero R's Avatar
Just in time to die
If you use what ATP gives you it will reduce the size of the turbine outlet, unless they got a new way of doing it, I have no more turbo's for sale, all are accounted for, I will be getting more very shortly but I think I am going to stick with just selling complete kits, I'm not to sure if I wanna sell just turbo's, it's just easier to sell the entire package.
-Sean
Old Dec 16, 2003 | 04:39 PM
i can sell you the gt40 non-bb for $750
Old Dec 16, 2003 | 04:48 PM
rx7tt95's Avatar
Photo Diety
Just talked to ATP. There's an extra cost option ($95) and they can machine it for you so there isn't the restriction issue and it'll mate to a 3" downpipe.
Sean, when are the complete kits going to be in? I called and left a message today. Oh, one other question....the GT35/40...does that use the 88mm or the 82mm compressor (or neither)?
Old Dec 16, 2003 | 09:46 PM
Carl Byck's Avatar
Mad Man
Sean, can you do a 4" vband outlet? LMK.
Old Dec 17, 2003 | 01:48 PM
Veteran: Navy
When the flange on the housing is machined, it will fit the 3.5" v band. If you want a 4" v band, the housing has to be modified and weld on a 4" v band flange. Email me at rotaryextreme@aol.com for more info. Thanks.
Chuck Huang
Old Dec 17, 2003 | 03:27 PM
Zero R's Avatar
Just in time to die
Hey now that's the first time I've seen Sean spelt CHUCK
You could run a 4" exhaust if you wanted to.
ATP must have changed what they were doing then, good for them it only makes sense.
I have kits whenever you want made to order just let me know what you want.
Wheel on the 35R is 82mm.
hope that helps, Sean
Old Dec 17, 2003 | 09:16 PM
Carl Byck's Avatar
Mad Man
Thanks Shuck Sean any customer dynos????????????????????????????????????????????? ?(on the 40R)
Old Dec 18, 2003 | 03:12 PM
rx7tt95's Avatar
Photo Diety
Thanks for the reply on the 35/40 wheel...I have the 88mm wheel on my T78 now and love the top end but was contemplating the 35/40 as a street turbo. Me thinks I'll like the 40R better.
Old Dec 19, 2003 | 09:32 AM
vspecpgt's Avatar
michel are you going with the ball bearing or non bb? i like this turbo too....
