Oil leaking, pretty bad....
Old Dec 12, 2003 | 10:16 AM
rotary_neubie's Avatar
Question Oil leaking, pretty bad....
Hey guys, I have an oil leak. Its up around the front set of plugs, and gets my block heater all full of oil, and apparently undercoats the floor of my car as I drive, with oil..... is this a quick fix? Or a full rebuild. Oil seems to gather up where it says 12a.....
Old Dec 12, 2003 | 10:53 AM
Critoris's Avatar
Ooooh, sounds like a dowel pin leak. Nothing to do but rebuild, really.
Old Dec 12, 2003 | 11:03 AM
Rx7carl's Avatar
Airflow is my life
Sure sounds like it. Clean it up and figure out where its comming from.
Old Dec 12, 2003 | 11:29 AM
bouis's Avatar
I agree with the other guys: look and see where the oil is coming from. If it's coming from the top of block, around the "12a" symbol on the front rotor housing, yeah, it's probably a dowel pin leak.
Those are messy, but as long as it's not a lot of oil coming out, you can drive around with one indefinately.
Edit: But watch your radiator hoses! Oil ruins them!
Old Dec 12, 2003 | 05:35 PM
I kinda figured it would require a rebuild, yeah, its comming from the top of the engine. That doesn't really cause any damage to anything right, just messy? I would like to put a 13b in anyhow... that can't happen anytime soon unfortunatly. Just have to live with it. Has anyone had a good experience with any of that stuff you put in your engine to stop it from leaking, or is that just a gimick?
Old Dec 12, 2003 | 08:01 PM
Cody's Avatar
SKELETOR!
How exactly does a dowel pin leak?
When I opened my 13b block those look like just plain metal rods....what makes them leak?
Old Dec 12, 2003 | 10:44 PM
DAMN YOU DOWEL PIN....DAMN YOU AAALLLLLL!!!!!!
Old Dec 12, 2003 | 10:49 PM
brianw's Avatar
I have a small laek there also. I wouldn't use any stop leak as htese motors use the oil different than ordinary cars. They burn it. May clog something but I'm not 100% on it,only say 99%
alphawolff
Nov 17, 2015 05:57 PM
Cameron38
Aug 19, 2015 06:08 PM
sypath
Aug 16, 2015 12:06 AM
