13b weight
Old 12-11-03, 12:23 AM
Ahhhh Motherland!
austinsFD's Avatar
13b weight
how much does a 1993-1994 mazda 13b twinturbo rotary engine weigh?
Old 12-11-03, 01:13 AM
c00lduke's Avatar
Me and a couple of my skinny bitch *** friends are going to be carring one out of the basement in about a week so i can tell you then.
I think you also might be able to find info on it in the whole v8 vs 13b threads, I know i've seen it.
~Luke
Old 12-11-03, 01:24 AM
Do it right, do it once
turbojeff's Avatar
410lbs including turbos and all accesories, PS, AC , airpump etc. IIRC.
Old 12-11-03, 06:24 AM
Constant threat
bajaman's Avatar
13B or 13BREW?
BIG difference in weight, the FD engine (13BREW) has all the turbo weight. It DOES weigh in the 400+ pound range.
Old 12-11-03, 08:03 AM
wickedrx7's Avatar
How much does just a short block weigh?
Old 12-11-03, 11:32 AM
David Beale's Avatar
I picked one up once, then almost fainted. Must be well over 300 lbs. Lifted it over 3' into the back of my SUV.
Old 12-11-03, 12:39 PM
soru81's Avatar
Shortblock (flywheel, waterpump, thermostat, pulleys and block) ia about 70kg (around 140lbs). One man can put it out of the car.
Old 12-11-03, 02:20 PM
Ee / Cpe
XSTransAm's Avatar
400 lbs? that means that 250 lbs for the ps, ac, turbos ect.... that seems a little on the high end of guessing to me
Old 12-11-03, 07:49 PM
Super Snuggles
jimlab's Avatar
Jeff's not guessing, but I suspect that soru81 is. Just the rotors (9.5 lbs. ea.) and the flywheel (22 lbs.) of a 13B-REW weigh 41 lbs.
BTW, 70 kg would be 154 lbs.
Old 12-11-03, 08:22 PM
built my own engine
93BlackFD's Avatar
when i shipped my motor to pineapple racing the second time, it weighed in at 145lbs with a 9.5lb flywheel, just the block/flywheel
Old 12-11-03, 11:20 PM
Super Snuggles
jimlab's Avatar
Substitute a stock flywheel and you're at about 155 lbs., which would support the 70 kg figure. My apologies to soru81 for doubting.
However, the cast iron exhaust and turbo manifolds are extremely heavy. The P/S and A/C, brackets and pulleys weigh about 38.5 lbs., according to the weight reduction matrix posted elsewhere. Add in an alternator (10+ lbs.) and air pump (20 lbs.), the lower and upper intake manifolds coils, rat's nest, a lot of plumbing, motor mounts, MOP, etc. and you could pretty easily come up with another 255 lbs. of weight.
Jeff claims his local truck scales are spot on, and although I like to give him **** about it, I believe his weight is very close. However, the scales have an acceptable error of 0.2% or 2 lbs. per every thousand pounds, and a minimum increment of 20 lbs., so it could be 20 lbs. in either direction, especially since it was in the back of a pickup at the time.
Old 12-12-03, 12:12 AM
turbojeff's Avatar
Truck scales RULE!
Old 12-12-03, 12:40 AM
Super Snuggles
jimlab's Avatar
Jeff, here's your vindication, from Mazda's own lips...
Page 10 of the 1993 Mazda RX-7 sales brochure...
The last paragraph on the page reads as follows...
"The net result is a new powerplant, including engine
ancilliaries, exhaust system, and final drive, that is much more
powerful, yet at approximately 320 kg weighs no more than
the previous engine"
Now 320 kg is 704 lbs. (1 kg = 2.2 lbs.), and it just so happens that I know the weights for the rest of the "stuff" mentioned in that paragraph...
Part - Weight (Weighed by)
Final drive (differential) - 77.6 lbs. (Me)
Transmission (5 speed) - 112 lbs. (Me)
Powerplant frame - 22.3 lbs. (Bernd Kluesnener)
Driveshaft - 14 lbs. (Jeff Hoskinson)
Pre-catalytic converter - 22.6 lbs. (Max Cooper)
Catalytic converter - 33.5 lbs. (Gene Felber)
Cat-back exhaust - 33.6 lbs. (Max Cooper)
Total: 315.6 lbs.
704 lbs. - 315.6 lbs. = 388.4 lbs., which with the weight of your pickup included, is probably within the acceptable range of error for the truck scale (415 - 388 = 27 lbs.) you used. Interesting. I think we have as close to an accurate weight for a 13B-REW with all accessories as we're likely to get, short of sitting one on a corner scale.
388.4 lbs.
Old 12-12-03, 12:54 PM
wickedrx7's Avatar
Okay Jim so block alone weighs?? 150lbs, is this the concensus?
Old 12-12-03, 01:48 PM
turbojeff's Avatar
Total: 315.6 lbs.
388.4 lbs.
Sweet! Thanks Jim.
Old 12-12-03, 02:05 PM
soru81's Avatar
Yes, I am guessing. I didn't weight it. But one man put the shortblock I described on the back seats of my car, and he wasn't more than 100kg.
Old 12-12-03, 03:19 PM
yy4u's Avatar
Jim, are you sure the 320kg includes the PPF?, seems like the extra 22.3lbs would put jeff's weight spot on, and i'm not sure why it would be included
Old 12-12-03, 06:07 PM
Super Snuggles
jimlab's Avatar
No, but it's probably a safe assumption. The brochure says the final drive but does not specify the transmission either. If we take them literally and just subtract the weights of the exhaust system and final drive, then the weight of the engine and accessories is much too high...
Differential - 77.6 lbs.
Total: 167.3 lbs.
704 lbs. - 167.3 lbs. = 536.7 lbs.
I assume they meant to say "powertrain" instead of powerplant. Basically, everything between the shocks from front to rear in the picture below...
Old 04-15-10, 12:32 PM
javielo709's Avatar
I'm working on my 7th and the freaking engine is kicking my nerves. I do have Carpal Tunel Syndrome and working on the engine without a crane or hoist. I'm lowering the engine between the frint frame and the front suspenssion assembly. Is a pain but, the 13B Turbo is heavier than I thought.
MILOS7
05-09-16 06:39 AM
Boans
V-8 Powered RX-7's
09-25-15 04:34 PM
Quick Reply: 13b weight
