who can get me these wheels...
Old Oct 9, 2001 | 10:04 AM
wptrx7's Avatar
Newb Photog
i'm looking to get the gold/ bronze volk te37 18x8.5 in front and 18x9.5 in rear. i have a set of (4) nitto 225/40/18 tires nt555, i know those should fit for the front, what size tires should i get for the rear? if it matters i eibach springs and bilstein shocks.
luigi
94 fd blk
for any wise ***, i don't plan on putting four tire in the front i just happen to have four of the same size tires that i won in maple grove last year and never got to use them.
Old Oct 9, 2001 | 10:06 AM
wptrx7's Avatar
Newb Photog
these wheels in bronze:
Old Oct 9, 2001 | 02:04 PM
Dr Wankel's Avatar
Altitude SUCKS!!!
you should be able to run at least a 245 on front if not a 255 the stock wheels are 8" wide and will fit a 245 with ease. on the rears you may be able to use as wide as a 275 or maybe 285. Just make sure to get the correct offset.
Old Oct 9, 2001 | 07:01 PM
ZoomZoom's Avatar
SEMI-PRO
those wheels are for sale on the website www.thepartstrader.com used for 2700 wheels and tires.
Old Oct 9, 2001 | 08:37 PM
ARD T2's Avatar
Considering you already own the 225/40, go ahead and use those. You will be fine, in fact they will be the nearest to the stock diameter and I would reccommend a 265/35 for the rear. A 255 would be closer to the 225/40's diameter, but it is close enough and you would eventually want to run a 235/40 and 265/35, or a 245/40 and 275/35. That's what will keep your proportions proper.
I can get you those wheels new. Give me a PM if you are interested and if you are going to get them from partstrader, check to see if they include the centercaps. You might as well get them new because it will be right there and you don't need their tires neccessarily. I can provide you with the Nitto's for the rear as well.
Thanks, Rishie
Old Oct 11, 2001 | 11:51 AM
wptrx7's Avatar
Newb Photog
ard t2 i just pm you.
luigi
94 fd:uner construction
Crixtala
SE RX-7 Forum
92
Oct 30, 2016 11:24 AM
DVSseven
Interior / Exterior / Audio
801
Jan 30, 2009 04:49 PM
93'roadwarrior
May 30, 2006 05:17 PM
Cramerizking
48
Mar 8, 2006 07:04 PM
sleejay
Nov 8, 2004 10:33 PM
