Sponsored by: CARiD
It wont START!!
Old Dec 7, 2003 | 01:34 PM
d86rx7's Avatar
Angry It wont START!!
I was using it during the day time and then after i parked it by the lot and then come back i didnt want to start i dont understand why?? Batt is fine cuz all of my lights still work ( Headlight, Dash, Dome , and even making the seatbelt beeping noise) oh yeah and gas is almost at FULL. I would appreciate everyones take for this , and by the way my car is still at the parking lot. Luckily a kind couple gave us a lift back home
Old Dec 7, 2003 | 04:04 PM
d86rx7's Avatar
ok another addition to my problem, i was told that it might be the Fuel Pump, please can someone give me an input on how to fix this problem
Old Dec 7, 2003 | 04:09 PM
Re: It wont START!!
Which parking lot?
Old Dec 7, 2003 | 04:14 PM
But, really this Forum has so much to offer for new comers if you serch.
When you say it won't start that is not a good enough explanation. Does it crank or just click, or what.
Old Dec 7, 2003 | 08:52 PM
wwilliam54's Avatar
it WILL run
check the dizzy/cas or whatever for cracks, it could be from condenstation getting into the ignition
Old Dec 7, 2003 | 11:02 PM
gambone's Avatar
Is this a Tll if yes go to 3RotorRocket and check out the repliy I just made,if not I be still lookingfor a fuel problem
Old Dec 8, 2003 | 10:22 AM
d86rx7's Avatar
Well im really thankfull for all the people the responded, but i wish i am able to explain more about the problem, it weird
Old Dec 8, 2003 | 10:26 AM
d86rx7's Avatar
Please understand i am a Noob at the rotary life, so i apologize if i am not able to tell you about the problems, correct me if im wrong but RX7 are awesome
Old Dec 8, 2003 | 10:28 AM
d86rx7's Avatar
Ne way back to the topic. My friend told about something that might have gotten some mositure arounf because it was rainning at the time when it did not want to start. Somewhere by the rotor, cuz when i went back to the parking lot and try starting it was good
Old Dec 8, 2003 | 10:32 AM
Maybe you flooded it.
Take EGI INJ fuse off and crank it few times (if your veh cranks) and put the fuse back in and it should start if the cause was flooding.
Old Dec 8, 2003 | 08:34 PM
wwilliam54's Avatar
it WILL run
yup that what i said
and btw its no the engine rotor, just the cas rotor
get a new cap
Old Dec 8, 2003 | 10:26 PM
xteg's Avatar
If you turn the ignition to the on position, you should be able to hear the fuel pump turn on. Listen to the rear of the car(toward the trunk inside) as you first turn the key to the ignition position, it'll make a sound as it builds up pressure, then turn off in preperation for starting. If there is no sound, check the fuse, then the relay, and then the fuel pump.
Old Dec 10, 2003 | 04:00 AM
d86rx7's Avatar
Wow i really appreciate all of your help thanks alot alot alot
Old Dec 13, 2003 | 02:56 PM
dog's Avatar
dog
my 1990 rx7 won't start i checked the plugs and they're wet i guess the engine is flooded i disconnected the fuel pump and crank it so i can get rid of the gas i cleaned the plugs checked them for spark and they're good, pluged in the fuel pump and it won't start they get wet again like in a second so i'll appreciate if somebody gives me any advice on how to fix it thanks.
Old Dec 13, 2003 | 05:39 PM
chairchild's Avatar
50mpg - oooooh yeah!
get some new sparks - always helps
Old Dec 14, 2003 | 01:01 AM
dog's Avatar
dog
thanks i'll get some.
Old Dec 17, 2003 | 11:10 PM
dog's Avatar
dog
anybody knows if theres any other fuse or relay for the fuel pump? i checked the relay by the driver side and it works, i checked the fuel pump manually and it works, but with the switch it doesn't.
ZacMan
Sep 19, 2015 09:20 PM
sherff
Sep 12, 2015 12:22 PM
whinin
Sep 5, 2015 11:52 PM
