gsl-se shutting down
Old Dec 5, 2003 | 09:26 AM
hello all wondering if i could get some help on this one
i have a84 gsl-se it has msd ignition magnecore wires ngk's rb header presilencer k&n cone air pump gone prob is it seems like every 7 months or so i will be driving the car and after a while it bogs out kinda like the fuel is being stopped we have check the pressure it has it and spark the pump whines really loud when it dies and then if u try to start it it seems like its flooded but then u let it sit for 2 hours or so it sarts up and runs pump and filter have been replaced as well as new gas cap and injectors pulled and sent to out to be cleaned any help is greatly appreactiated
allan
Old Dec 5, 2003 | 10:04 AM
hotty's Avatar
fuel filter could be clogged, fuel tank might be full of rust.. check those
Old Dec 6, 2003 | 08:37 AM
we have replaced the fuel pump and filter and dropped the tank to see if the tank was dirty it was fine the pickup in the tank was clean and we blew out the lines we have done just about everything except replacing fuel lines today i put an inline pressure guage in shows good pressure thing that baffles me is it only happens every couple of months
Old Dec 6, 2003 | 10:37 AM
rhinor61's Avatar
QUOTE: seems like its flooded but then u let it sit for 2 hours or so it sarts up and runs.
Well when it stops running or won't start, pull the spark plugs and check them. Are they dripping with fuel?
If it was flooded letting it sit for 2 days would not even unflood a rotary engine.
You also need to check for spark on both leading and trailing, I use a inductive timing light a put it on each coil wire to make sure I have good spark.
So, you have the proper fuel pressure, you have spark, I assume your motor still has good compression (cause a weak compression will not start a hot engine) and clean air coming into the engine thru air filter.
HMMM.... the engine has everything it would need to start.
BTW, my SE had a little cone shaped fuel filter stuff up inside the 3/8" (??mm) supply line right before it goes into the fuel pump. It was plugged so I pulled it and cleaned it out, then stuffed it back inside the fuel hose.
John
Old Dec 6, 2003 | 12:16 PM
hotty's Avatar
hmm.. ok.. I had a lil problem that NO ONE on this forum has every described, and after months of frustration I found the lil bastard an fixed it ... I had the same problem as you, running out of fuel, etc. Check your fuel regulator, and from the drivers side, under the hood, looking at your 'rats nest' make sure those connections are good. If this doesnt help, start the car, and have it idle, while you wiggle underneath those connections. Mine ended up having a loose ground to the block underneath all that ****, and once I pulled it all apart, checked all the vaccuum hoses, I found it... tightened er up real good, and no probs since .. Hope that helps man, and be glad you have an SE, I wouldn't have it any other way
Old Dec 6, 2003 | 02:51 PM
thanks for the advice i will try those ideas tonight and see what i can find btw how can i put a pic of my car up here i havent seen many 7's with 17 inch wheel like mine
Old Dec 6, 2003 | 05:49 PM
hotty's Avatar
you need at least 100 posts to upload your car into your avatar, and I think 100 to put it into your sig. Do the 17's look good?, I actually like my 14's .
squirrels
Sep 1, 2024 09:52 AM
NickNac113
13
Oct 1, 2015 09:25 PM
93FD510
Oct 1, 2015 02:00 PM
