Ecu!
Old Oct 7, 2001 | 10:58 PM
Question Ecu!
Where are the second gen's
ECU located??
Old Oct 7, 2001 | 11:04 PM
pp13bnos's Avatar
Pineapple Racer
Its located at the passangers foot area, under the carpet, and a metal sheild. Should be 4, 10mm bolts holding the shield on. couple more holding the ecu. CJ
Old Oct 8, 2001 | 09:38 AM
95R2-89TII Ground Zero's Avatar
Banned
It is in the passenger floor panel under the carpet and the metal shield like said above. Just remember to unplug the ECU on the passenger side right near the opening in the firewall. There is a green clip in there that the engine harness is connected to, and if you try to unplug and pull like I did, it won't move until you unplug that.
Erosangel
Sep 18, 2015 10:28 PM
Erosangel
Sep 18, 2015 04:06 PM
