Do fog lights block airflow to aftermarket intakes?
Old Oct 7, 2001 | 10:17 PM
annarborman76's Avatar
Question Do fog lights block airflow to aftermarket intakes?
It looks like the right fog light, and especially the black piece of plastic next to it, covers the area where the aftermarket intakes get their air from. Has anyone remove their fog lights or the black piece of plastic to free up airflow? Do you think it makes any difference?
Old Oct 13, 2001 | 10:38 AM
Does anyone have any thoughts on this?
Old Oct 13, 2001 | 02:28 PM
Scorpio's Avatar
I've read that the black pieces on the sides are to force all the incoming air to go through the radiator...I would leave them in place help out the cooling system.
Old Dec 12, 2001 | 12:59 PM
Daily1's Avatar
93 R1
I dont know?
they might block a litthe airflow but not much
Old Dec 12, 2001 | 06:52 PM
bajaman's Avatar
Constant threat
perplexed by your question....
Uh....by aftermarket do you mean one that resides inside the engine bay, like A'Pexi, HKS, etc.? 'Cuz the keyword there is INSIDE the engine bay. Foglights or lack thereof would have no effect.
The stock intake snorkel affair thingy is in clear airflow. I took out my side panel grill pieces and haven't noticed any difference in cooling, if anything cooling seems IMPROVED.
Airflow thru the nose and radiator on an FD takes a sort of convoluted path anyway, the undertray helps direct most of the outflow over the turbos and out the underside of the car, at least as far as the passenger side is concerned.
So I say, NO, they don't block airflow to an aftermarket intake.
streetlegal?
Mar 17, 2022 02:46 PM
