vacuum pressure
Old Nov 29, 2003 | 04:43 PM
exodus82's Avatar
vacuum pressure
what pressure should the vacuum lines be at idle????
Old Nov 29, 2003 | 08:43 PM
Rx7carl's Avatar
Airflow is my life
Manifold vacuum? Depends on idle speed and health of the engine. My racecar with 150psi compression and idles at 700- 18-20"hg. My streetcar with 90 psi compression, idles at 800- 12"hg.
Old Nov 29, 2003 | 09:27 PM
matthewpims's Avatar
my 84 se with 200+k miles has 16 inlbs of vacuum at idle (roughly around 900 rpm)
Old Nov 30, 2003 | 05:17 PM
exodus82's Avatar
does your vacuum pressure hold steady at 16 inlbs at idle???
Old Nov 30, 2003 | 05:39 PM
Rx7carl's Avatar
Airflow is my life
My racecar is rock steady, cant say the same for the streetcar, the needle is a blur LOL.
alexdimen
20
Oct 23, 2015 01:50 PM
ZacMan
Sep 19, 2015 09:20 PM
t-von
Sep 10, 2015 01:56 PM
Frisky Arab
Sep 4, 2015 06:17 PM
