Power FC where to buy apexi 3 bar map sensor
Old Nov 29, 2003 | 10:16 AM
Question where to buy apexi 3 bar map sensor
Does anyone know where i can buy a apexi 3 bar map sensor from on its own as i already have an avcr,thanks.
Old Nov 29, 2003 | 02:34 PM
Fish's Avatar
Royston, mail me offline. I have the Apexi 3 bar fitted and can tell you its only a Denso unit. I will check it and let you know the part number.
Dan
Old Nov 30, 2003 | 11:46 AM
sevenin7's Avatar
and the cost is ???
Old Nov 30, 2003 | 08:09 PM
weaklink's Avatar
Resident Retard
$69 from motorsport dynamics in CA. Should be on the way, took like a month to get.
Old Nov 30, 2003 | 08:10 PM
weaklink's Avatar
Resident Retard
http://www.motdyn.com/
not listed on the web, you will have to call...
Old Dec 1, 2003 | 03:23 AM
Fish's Avatar
Here are the readings from the top of the Apexi 3 Bar map sensor.
Denso DPS-310-2000A
949940-6270 5V
So being a Denso unit, it should be able to be bought anywhere.
Dan
Old Dec 1, 2003 | 09:05 AM
weaklink's Avatar
Resident Retard
good luck finding it at a major parts store online-I haven't been able to.
Old Dec 10, 2003 | 08:00 PM
weaklink's Avatar
Resident Retard
got mine in this week...truly plug and play. Peak boost 1.45 on the commander woohoo!
Old Dec 11, 2003 | 01:59 PM
Fish's Avatar
Weaklink, where did you get it from and how much?
Thanks
Dan
Old Dec 11, 2003 | 07:52 PM
weaklink's Avatar
Resident Retard
motorsport dynamics in CA. Took a while, read the previous posts and you will get the website and phone #. It is not listed on the web, so you will have to call.
Old Jan 14, 2004 | 02:43 PM
spoolin93r1's Avatar
i just got off the phone with motor dynamics and they have no idea what i was talking about. i gave them the part number and explained it's not a factory mazda part. the guy said to ask you if you know the number they used to get it versus the actual denso part number. i really really need to get this thing. can you help?
Old Feb 2, 2004 | 04:28 PM
SPOautos's Avatar
Hey, where did my $$$ go?
I'd also like the info if anyone has it cause I need to get a 3 bar asap!!!
Thanks,
STEPHEN
Old Feb 2, 2004 | 05:08 PM
sevenin7's Avatar
SPOautos can i use your maps from turborx7.com ( PLEASE read my thread : maps for 1.15 bar ) .
thanks
Old Feb 12, 2004 | 01:35 AM
after receiving an e-mail from them, they want $162+ shipping
Old Feb 26, 2004 | 06:17 PM
RotorJoe's Avatar
Hooray For Boobies!!!
Rx7Store.net
Old Feb 26, 2004 | 06:22 PM
he doesn't have the apexi/denso unit, i've done talked to him
Old Feb 26, 2004 | 06:27 PM
RotorJoe's Avatar
Sorry
Old Feb 26, 2004 | 07:08 PM
paximus's Avatar
20B FD|20B Cosmo|S5 TII
does this unit have more resolution than the gm 3bar sensor?
Old Feb 26, 2004 | 07:18 PM
no, just better oem compatability
Old Jul 28, 2009 | 07:08 PM
Max_Spd's Avatar
UA DRVN
Bringing this back from the past, I need a 3-bar and I dont want to buy the overpriced Apexi Map Sensor, so has anyone had luck with getting a Denso 3-Bar listed on the Apexi? And if so, where and how much!!!
Thanks...
Old Jul 29, 2009 | 05:51 AM
Banzai-Racing's Avatar
Rotary Specialists
GM 3 bar and PnP harness http://www.banzai-racing.com/product...er_harness.htm
Old Jul 29, 2009 | 09:22 AM
Max_Spd's Avatar
UA DRVN
Thanks for the link, but I was aware of the unit you had with the harness...
The main reason for wanting the Denso/Apexi unit is that i dont have to tune/set-up/configure the unit...unlike the GM!!!
Old Jul 29, 2009 | 09:32 AM
Rotary Specialists
Of course you have to setup and tune the denso/apexi unit, just like the GM. You really think you can plug it in and crank up the boost? You will be looking for a new engine very shortly if you don't tune.
Old Jul 29, 2009 | 09:43 AM
Max_Spd's Avatar
UA DRVN
Sorry, It came out wrong...I meant I dont have to dial in the Power FC to accept reading numbers off the GM unit to match what the OEM unit would show at atmospheric pressure...meaning +0- Or at least thats what i heard...
Old Jul 29, 2009 | 10:48 AM
Rotary Specialists
The PFC does have a preset for the apexi/denso sensor (option 1), which still needs calibrating if you want it to read "0" at your elevation. The scale and offset for the GM 3 bar is not top secret. If you have a datalogit it takes all of two seconds to set up and saves you $100.00. It is after all your car/money and if you feel like spending $200.00+ for a Map sensor, you can.
