2 years later, the T2 comes to life
Old Oct 7, 2001 | 01:35 AM
cymfc3s's Avatar
I Raise Chickens
Well, after more than 2 years of work, my rx7 finally roared back to life. And i do mean roar. I started it up with just the downpipe. Nothing beats the sound of the opened up exhaust rotary, especially hearing my own. Mike and I really rigged things to get it running. It has 1600cc secondary injectors, but not plugged in. (the ecu wont run the bosch injectors) and it has no electronic metering pump. I also couldnt find the air flow meter, so i used my old 93 Probe GT airflow meter instead, hoping it would function well enough to work. Well, the first cranking we kinda flooded it a bit by fooling with the MAF, cleared it out by cranking it over a second time. But the third crank, vooom, fired up immidiately. The AWS kicked in, reved up to about 2,800 held it for awhile, then ran about 2,000 while the motor heated up. Motor ran smooth, had perfect throttle response with the Probe air flow meter. No hesitations. I let it run for a bit, then revved it up and killed it before the neighbors started to complain. I need to un-rig it before i can drive it around alot, but the biggest hurdle is over. And i am a very proud turboII owner. =]
Old Oct 7, 2001 | 02:20 AM
fcturbo2's Avatar
man i cant wait to build my motor and start installing all the parts i collected for more than 2 years!..bigger turbo and haltech and other stuffs. Congrats man!...Im also considering of getting the car painted to CYM. Such a gorgeous color for FCs.
Old Oct 7, 2001 | 02:24 AM
RarestRX's Avatar
NA Powah, Every Hour!
Yo,
Seth...congrats!! FINALLY! It's like one of the signs of the Apocolypse...the CYM FC lives!! AHhhhhhhh! *grin* Now you can maybe beat me. Maybe. *wink*
Your friend at 8000rpm,
KS
1989 GTUs "Bring it!!"
Old Oct 7, 2001 | 02:39 AM
RX-7 GT's Avatar
HyperREV.com
cool man! im sure its going to serve you proud. keep us updated on the status
Old Oct 7, 2001 | 12:29 PM
supergoat's Avatar
Eggs are like fowl cheese
wow! You got it to run by using the VAF from a Probe GT? Awsome!
Old Oct 7, 2001 | 09:06 PM
cymfc3s's Avatar
I Raise Chickens
Yeah, it seems to run good with the probe VAF. Ran good today, reved up to 4k no prob.
Old Oct 7, 2001 | 11:55 PM
TonyTurboII's Avatar
Glock Lover
Sweet, go kick some ***!
msilvia
28
Apr 14, 2016 12:58 PM
