Alternator Power
Old Nov 25, 2003 | 11:40 AM
Racer79's Avatar
Alternator Power
Seeing as how my lights seems to dim at anything below 2000rpm, and the alternator does seem to make a little noise, I was wondering, are there any kind of upgrades I can put on in this respect? I was planning on eventually adding an amplifier, so I'm assuming the stock alt will not cut it if it can't handle just a regular charge. What can I do to improve the voltage coming from the alternator?
Old Nov 25, 2003 | 11:46 AM
K-Tune's Avatar
FD Daily
get a new one..with more output.
Old Nov 25, 2003 | 11:50 AM
Racer79's Avatar
Alright, where do I find the output rating? Who makes an alternator with higher output than stock?
Old Nov 25, 2003 | 01:52 PM
mar3's Avatar
Administrator
It's been here waiting for you...
Old Nov 25, 2003 | 05:43 PM
Racer79's Avatar
My bad, thought I had already looked there, thanks .
Old Nov 25, 2003 | 11:16 PM
RacerX7fb's Avatar
paradox
I went and got an alternator off a 86-88 FC for cheap at the junkyard.. 70 amps just plug & play
Old Nov 26, 2003 | 03:40 PM
Sk8r_dude's Avatar
Zoom - Zoom...
use a third gen one?
Old Nov 26, 2003 | 09:33 PM
Pele's Avatar
Right near Malloy
All cars run on 12-14 Volts.
Voltage does not need improvement, you need more current (Amps).
Imagine electricity as it is water...
We've gotta wash your car... Okay, so we need a certain pressure of water...
Too little pressure and you won't be able to spray the water on your car...
However, turn a huge pressure washer on your car, and damn... You've got no paint...
Voltage is pressure... The Right ammount is necessary.
So... Lets see, we've got some decent pressure... What're we gonna put this water in?
Soda can? Nah.. That wont do...
Swimming pool? That'll work, but it is kinda large...
5 gal Bucket... Perfect...
Volume (Size) is Amps... Too little is no good, too much doesn't matter.
Okay, so let's say you have a lot of water on reserve from the swimming pool. You're spraying with the hose... First of all you need the right hose for the volume of water... So what happens if you use too thin a hose and demand a lot of water... It'll burst... Hence:
If you use too thin a wire, it'll burn. Use the correct wire for your application. Fuses are purposefully thin to limit flow. If too much power is demanded. (Short circuit) they are supposed to burn.
The Shaolin
Sep 14, 2015 07:50 PM
rotor_veux
Aug 31, 2015 07:49 PM
sYnth.
Aug 19, 2015 06:27 PM
