dipstick tube pressure????
Old Nov 23, 2003 | 11:05 AM
Jodeny's Avatar
Indifferent
Does anyone know what would cause the oil dipstick to be pushed out of the tube almost all the way. My engine actually squirted oil all over under the hood out of tha dipstick tube....any advice anyone??
John
Old Nov 23, 2003 | 04:14 PM
EProdRx7's Avatar
Well I hate to be the bearer of bad news but in most cases the pressure in the oil pan has been the result of missing side seals. When the motor turns and makes compression that pressure it trying real hard to get out. If you have a broken side seal it pushes right by the oil seals and into the pan. The normal breather is not lage enough to bleed off the preasure and the next weakest relief is the dipstick. Sorry
Old Nov 23, 2003 | 05:44 PM
Jodeny's Avatar
Indifferent
Hey no problem, the motor is under warranty. Thanks for the info. Woud I be correct in guessing this would cause a stuttering idle and stuttering up to 4500 rpm until the revs are fast enough to at least sound smooth and a slight miss at idle?
John
Old Nov 24, 2003 | 01:24 AM
lacycw's Avatar
Yeah, I took apart a 12A that was shooting the dipstick to the ceiling in my garage when it was revved up. It had been overheated and a few side seals were pretty much welded into the rotor in the down position.
Cooper
Old Nov 24, 2003 | 09:28 AM
Jodeny's Avatar
Indifferent
Ok thanks.
John
Old Nov 24, 2003 | 01:23 PM
Barwick's Avatar
SCCA Rookie
Or it could just be what I had on my race car, and that is the fact that the breather was capped off (or maybe in your case clogged).
Old Dec 5, 2003 | 09:22 AM
Jodeny's Avatar
Indifferent
Thanks for the info- you were correct. What would cause this?
Thanks,
John
Old Dec 5, 2003 | 10:13 PM
EProdRx7's Avatar
Well the last time this happened to me it was because of some over agressive porting. ran great till the side seals on the rear rotor got hung up in the port and snapped. Result was compression straight into the crankcase and in this case it pushed all the oil out into the catch tank. On a stock motor this could be caused by carbon build up or carbon lock. If the motor had been dramatically over heated the side housings could be warped. If this were the case you would have regular over heating problems.
Old Dec 10, 2003 | 10:33 PM
ErnieT's Avatar
Living life 9 seconds at a time
Your having blow by caused by a pinched corner seal or collapsed side seal. Either case, you'll need to tear down your engine. Sorry to give you such bad news.
Old Dec 10, 2003 | 10:34 PM
ErnieT's Avatar
Thanks,
John
Detonation can cause it.
Old Dec 11, 2003 | 08:08 AM
Jodeny's Avatar
Indifferent
ahh its not such bad news.... these cars aren't too bad to work on after 8 years...
John
Old Dec 15, 2003 | 08:51 AM
CrispyRX7's Avatar
Polishing Fiend
John,
Check the PCV system - check valve, vacuum lines etc.
If there is no way to vent crankcase pressure the fist item to pop is usually the dipstick, Every engine pressurizes the crankcase so check the simple first before starting a complete engine teardown.
FWIW
Crispy
Old Jan 11, 2004 | 08:47 PM
Jodeny's Avatar
Indifferent
Update,
it was the black outer oil control ring seal. It got progressively worse from 0 miles to 900.
John
Shainiac
Jul 17, 2019 02:20 PM
armans
Sep 6, 2015 09:02 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
