Microtech Looki MT WideBand :)
Old Nov 22, 2003 | 09:54 PM
kabooski's Avatar
Laying Down Rotary Law
I got the car running again after taking the turbo and manifold off for some ceramic coating
MY AFR's at WOT in most gears
was in the 11.9's
My IDLE AFR is 11.1-11.3
Pretty bad *** WideBand!
Old Nov 22, 2003 | 11:00 PM
Turbo Timmy's Avatar
Professional Lurker
did you buy that or is that the shop's?
Old Nov 22, 2003 | 11:03 PM
kabooski's Avatar
You like it eh
no its the shop's
Old Nov 23, 2003 | 03:52 PM
Piranha's Avatar
what 7
I take it those LEDs on the right signify rich, stoich and lean?
That seems VERY useful; something I wish my Tech Edge (1.5) had. I was planning on taking some markers and going over certain bars (it has a bar scale next to the #) so I wouldn't have to look directly at it while driving. Just like gauges with warnings LEDs to catch your eye, I'm glad someone put it on a wideband, it seems like a no-brainer.
Only thing is, I think it is priced out of the market.
Old Nov 23, 2003 | 04:09 PM
kabooski's Avatar
yep big bucks now with the current exchange rates
man I remember when it was 1.9 AUD to 1 USD
couple of years ago
I think my crusing AFR's are in the 14's
I get real good MPG for the mods I have
Old Nov 23, 2003 | 06:11 PM
10sec rx7's Avatar
Kabooski
nice eh? i got one of them as well! worth there weight in gold! how much boost are you on??
dont worry about mixtures at idle, you will never get a mazda to idle at 14:1!
Pirana,
the leds are for the selector switch ie petrol, alky, LPG
Dale
Old Nov 23, 2003 | 06:15 PM
10sec rx7's Avatar
Kabooski
another thing,
only use the tail pipe with it, dont mount the sensor in the dump pipe! it will get too hot and not read accurate,
also you will only get good mixture readings in 3rd and 4th gear, other gears just rev to quick to get anything happening
Dale
Old Nov 23, 2003 | 06:55 PM
kabooski's Avatar
My Tail pipe gets pretty HOT
is started to melt the paint on the probe pipe lol
I'm running 14 pounds sometimes spiking to 16 pounds on the top of 3RD and 4RTH gears
Old Nov 23, 2003 | 07:24 PM
10sec rx7's Avatar
hehehe yep they get hot but no where near as hot as the dump pipe!
what fuel you running it on??
Dale
Old Nov 23, 2003 | 07:57 PM
you need some washer fluid
Old Nov 23, 2003 | 08:39 PM
kabooski's Avatar
lol the hood is up
thats why the visibility is low thru the glass
93 octane
but when I go to the track I always use race fuel
Old Nov 23, 2003 | 08:47 PM
jreynish's Avatar
New Project on the Way...
is it suggested to put the sensor in the tail pipe for all WB02 or just for this particular one?
Old Nov 23, 2003 | 09:09 PM
10sec rx7's Avatar
depends on the unit,
the AF-1 works better in the back, i have a bung welded to the pipe at the back of my car and it works fine,
the LM-1 also needs to be mounted there as well
mulcryant
Oct 4, 2015 12:18 AM
