T-78 Vs. RX-6
Old Nov 22, 2003 | 07:16 PM
T-78 Vs. RX-6
I'm looking for single setup, right now.
I don't want insane big turbo, because I think I'm gonna use turbo for auto-x.
But... The only offer I got is just T-78.., so I'm thinking very seriously....
How do you guys think?
Can it be good solution for auto-X?
What is the pros and cons?
Old Nov 22, 2003 | 07:18 PM
$150FC's Avatar
Currently Winning
maybe gt35/40? i think a t78 is too big for autocross. supposedly the gt35/40 spools pretty quickly
Old Nov 22, 2003 | 07:45 PM
BoostedRex's Avatar
NorCal 7's Co-founder
I would have to agree with $150FC. The GT35/40 is a fast spooling turbo if you have a nice streetport. The RX-6 setup from Apex'i is a great AutoX setup though. It spools very fast and is capable of some really nice rwhp numbers. I would look at that first and then the RX-6. Don't forget about the T04E though. A bb version of that would be really nice for what you're looking for. Hope that helps some.
Zach
Old Nov 23, 2003 | 05:56 PM
Boosted!'s Avatar
T78 has to much lag for what you want. its a high rpm turbo.
Old Nov 23, 2003 | 06:44 PM
racer1's Avatar
flying apex seal
For auto-x definitely not a T78. That's mostly for drag/strip use. I would go with an RX6 if i had the money. I've tried it on a friends car with mild street porting and it's so fast spooling that i can even compare it with the stock twins.
Hope that helps
Old Nov 24, 2003 | 05:11 PM
Brian7's Avatar
If your looking for a "quicker" spooling turbo, and your only interested in using it for x-cross/track day's, I'd go with the RX6. Keep in mind that if you ever pop your engine and send any debris into the turbo, your screwed. I've yet to hear of a shop that will rebuild the turbo.
The GReddy unit on the other hand, spool's relatively fast on a street ported engine, and part's for it are almost common place. Pretty much every shop can rebuild it.
Good luck!
Old Nov 24, 2003 | 05:57 PM
rynberg's Avatar
If you are serious about auto-x, you should stick with the sequential twins. No single will provide as much low end power and as quick a spool. The Z06 is already dominant because of it's low end torque in auto-x, I don't think reducing your low end power is going to help you.
Old Nov 24, 2003 | 06:53 PM
fastcarfreak's Avatar
3rd motors a charm I hope
the rx6 turbo would prolly be your best bet if you are going single when it comes to auto-x.
Old Nov 24, 2003 | 07:03 PM
HeX's Avatar
HeX
01010010011010110
BNR3 above 15psi.
Old Nov 25, 2003 | 03:47 PM
Thank you guys.
I decided to go for rx6b.
I found one...
But it is not kit.. so..
Old Nov 25, 2003 | 04:42 PM
ZoomZoom's Avatar
SEMI-PRO
RX6 or GT3540 but the ones you want arnt the big ones for autoX
You want the RX6A or the Smaller GT3540 with the .86 A/R hot side. Those are both ball bearing and they are the smaller sized singles so they will spool better. Also they will both make as much or more power then single turbos. And low end spooling.
Old Nov 26, 2003 | 05:58 AM
Richierich's Avatar
crazy canuck
I have the rx6 and I do very well overall and in my class. It spools faster than my stock turbos by far.
rgordon1979
40
Mar 15, 2022 12:04 PM
alfred1976
1st Gen General Discussion
Oct 1, 2017 09:51 PM
GKW
Sep 28, 2015 04:34 PM
Bacon
Oct 11, 2001 11:28 PM
