speedo needle jumping up n down
Old Nov 21, 2003 | 01:48 AM
krazy_1st_gen's Avatar
can any of you guys help me. my speedo needle b trippin every time the car is crusing under 40 mph. but after 40 mph it goes back to normal. do you guys knoe whats wrong with it. any help would b appreciated. thanks
Old Nov 21, 2003 | 06:04 AM
DONNA's Avatar
sounds like something is binding the cable, maybe a spur or just in need of some graphite,,,i have replaced mine cause it was twisted in half,,,you may want to remove it from the tranny side instead of removing the cluster,,,,then you can inspect and lube it....more info to follow....
Old Nov 21, 2003 | 09:24 AM
French RX7's Avatar
Removing the cluster is pretty easy, putting it back in is something else entirely! I guess Mazda couldn't afford to make longer wiring and speedo cable. Removing it from the tranny, like ''DONNA'' said, is much easier. Your cable is probably coming apart, causing it to bind in the sleeve.
Old Nov 21, 2003 | 02:54 PM
thanks dude. i'll check it out right now
Old Nov 21, 2003 | 03:41 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
probablly the speedo cable. if it gets cut or frayed it'll jump. sometimes putting graphite mixed with WD-40 down the speedo cable helps lube it and smooth out.
dona1326cosprings7
Oct 29, 2015 06:47 AM
Thor 18
Sep 28, 2015 07:35 PM
izzolaw
Sep 28, 2015 06:03 AM
Casual_John
Canadian Forum
Sep 26, 2015 01:47 PM
