cluch
Old Nov 20, 2003 | 07:19 AM
keithr's Avatar
Newbie
Smile cluch
i think my cluch went out i can start it in 1st and and put it in 5 and try to go and it wont stall out is it my cluch
Old Nov 20, 2003 | 09:29 AM
Gregs's Avatar
yes it is your clutch, time to jack that bitch up and pull the tranny
dont hesitate to ask us for help, just try and make a little more sense (i had to read your post 3 times before i got what it said)
Old Nov 20, 2003 | 04:46 PM
brianw's Avatar
Thanks, I didn't want to be the one to say it.
While we are on the subject: My slave cylinder went otu so I rebuilt it,it still felt like it had air in the lines so i replaced it, it STILL feels like air in the lines. I'ts not consistant. Sometimes it feels tight other times I ahve to pump it up. I had someone pump the pedal while I worked the bledder(I put a line in fuid and had him pump till there were no more bubbles coming out of the line) He said the pedal felt good. Soud I have had the car running? Extra note:I have the same problem with the brakes! I've done a million brake jobs but this thing has me kinda baffeled.
Old Nov 20, 2003 | 07:21 PM
mar3's Avatar
Administrator
Did you bleed the unit out of the car?? If not, you will never get all the air out of the system. A bench bleed of the unit is mandatory for any master cylinder, brake or clutch, if it is a hydraulic unit...
PVD212
Aug 31, 2006 06:13 PM
I got an RX 7 too!!!
Oct 15, 2005 08:10 PM
okk0to
Jul 6, 2005 06:40 PM
coma13
Aug 29, 2004 08:15 PM
dtrigg
May 22, 2003 08:20 AM
