EGT sensor
Old Nov 16, 2003 | 03:17 AM
spinola's Avatar
EGT sensor
I am going to mount 2 EGT sensors one on etch rotor. dose anyone know wher too put the sensors for acuret temp on an rotary engien..
And whot temp is acuret for this setup
Mazda Rx7 1993
Greddy T88 34D Turbo
Greddy Stainless steel Exhaust manifold
Greddy 60 mm Racing Wastegate
Greddy 3Row FMIC
Greddy 100 mm exhaust
Greddy 100 mm Downpipe
Greddy Elbow
Greddy Type R Blow off valve
Greddy Pully kit
Greddy x6 52mm meters inkl EGT, boost, temp etc
Greddy Clutch line
NGK R625 10.5 Racing Spark plugs
Magnicore 8,5mm and 10 mm ignition cabels
Halmeter Wideband sensor
Streetport Deep Grove
Porsche 996 GT2 Brakes
Porsche 996 GT2 365 x 43 mm brake rotors
Porsche 996 GT2 Brake pads "Pagid Yello"
AEM Programmable Engine Management System
Hearly Racing tip seals 3mm
2x OEM Pumps in tank
1x SX External race fuel pump
1x SX High Flow filter
1x SX fuel regulator high flow
New fuel lines
K2rd Fuel rail secondary
Extra mounted catch tank
Bosch 1600 cc Injectors on secondery
ACT Xtreme pressure plate ZX3-XTR6 spec 780 Nm
ACT Disc 6 plates
Motul 300V
Motul inergel 50 "Motorcool"
Motul Gearbox
Pensoil Rear axel
Pensoil powersteering
Sparco PRO 2000 x2
Willians belts
Autometer pod
Carbonfiber rear wing
New Front stuntbar
Mazda Speed GTC Front
Mazda OEM 99 spec combo lights
New Paint OEM M6
www.rx7.nu
Daniel from Sweden
Old Nov 16, 2003 | 07:38 AM
Erdin's Avatar
Water Injection Specialist
EGT
when i spoke with rob at pineapple racing
he mantioned somthing about useing to egt gauges so i think he would be able to help.
Regard
Erdin
Old Nov 16, 2003 | 08:44 AM
spinola's Avatar
OKI
Thaks do anybody else know..
Daniel from Sweden
Old Nov 17, 2003 | 10:22 AM
surfpac's Avatar
You have to install probes before turbo, one in each runner. I believe around 1400 - 1500F at WOT is ideal temp.
Old Nov 17, 2003 | 10:28 AM
surfpac's Avatar
I'm actually going to do this to my upcoming custom twin turbo setup.
Old Nov 17, 2003 | 04:08 PM
jeff48's Avatar
Rotorally Challenged
HKS suggests the most accurate Rotary turbo mounting post turbo. 1400-1500 F (750-815 C) post turbo is safe and conservative. If you do go preturbo, I would expect to see 900C (1600) as an upper limit.
imitek
Sep 22, 2015 11:29 PM
rotor_veux
Sep 19, 2015 07:13 PM
