Sponsored by: CARiD
Stripped thread in rear wheel
Old Nov 15, 2003 | 01:20 PM
gemini55's Avatar
Newbie
While changing a rear tire, one of the lugs did not tighten but kept on turning. The dealer says that I have to replace the axle. Is this correct? A repair shop says that I have to change the hub. This does not sound right. Can anybody give me advice? I have a 1985 model. The front tires are mounted on hubs but I don't think the rear ones are.
Old Nov 15, 2003 | 01:45 PM
wwilliam54's Avatar
it WILL run
dp
Old Nov 15, 2003 | 01:48 PM
wwilliam54's Avatar
it WILL run
if its disc brakes on the back
then just get a new rotor
if its drum brakes youll need to tap the hole out or get a new axle
btw the dealer will gouge you if you get an axle
here is a good place
http://atlantarx7.com/rearend1gen.html
Old Nov 17, 2003 | 02:57 PM
813KR$'s Avatar
TEAM MAZDA
Or you can just drive it like I have done for years.
Old Nov 17, 2003 | 11:17 PM
duboisr's Avatar
T
Old Nov 17, 2003 | 11:23 PM
duboisr's Avatar
The stud will drive out the back of the axle flange . You can pull a new one in with a nut and several washers on the new stud . Get a long handle break bar to make it so easy that you will laugh at the dealer .
Old Nov 18, 2003 | 07:57 AM
813KR$'s Avatar
TEAM MAZDA
Sounds like a potential balance problem? Or am I wrong?
Old Nov 18, 2003 | 10:37 PM
duboisr's Avatar
The off weight is to near the center to be a large out of balance .
ChrisRX8PR
Aug 21, 2015 01:56 PM
Marty RE
Aug 17, 2015 09:36 AM
