'91 NA Differential Question
Old Nov 14, 2003 | 08:23 PM
Turbo 3's Avatar
Safety Guy
Have a '91 NA coupe and am wondering what the differential is. It is an AT trans.
Is it a LSD or not?
How do I know or did all '91's come as LSD's?
Old Nov 14, 2003 | 08:30 PM
Rxmfn7's Avatar
Do a barrel roll!
According to Mazda, there was no LSD offerered in 91, other than on the turbo. There have been rumored to have been a few coupes that did in fact have the LSD, but it was probably just avery rare mix up, or leftovers being put in. Id say the chances of you having one are slim to none.
Alternatively, there is always the good burnout test. Put one wheel in grass (or any slippery surface) and the other on dry pavement, and try and spin the tires. If they both still spin (esp the one on the dry pavement) then it is an LSD.
Old Nov 14, 2003 | 08:45 PM
bingoboy's Avatar
Lava Surfer
the only S5 NA to come with the fabled LSD was the GTUs model.
Cory Simpson's Avatar
I wanta be with the BUC!
Or you could just jack up the back of your car and have someone hold one wheel while you try to turn the other.
Although it would be a viscous, would that work
At any rate, if it is an open diff, the other wheel would just spin backwatrds as long as the car is in gear, while the rear end is on a jack.
Old Nov 15, 2003 | 09:56 AM
Turbo 3's Avatar
Safety Guy
Thanks for the help everyone. When on jack stands and turning one wheel, the other did go backwards.
Old Nov 15, 2003 | 10:55 AM
Center of The Universe's Avatar
I have an S5 NA. I have Viscous LSD. They are out there.
Old Nov 15, 2003 | 04:17 PM
Well then your car is probably a GTUs.
Old Nov 15, 2003 | 08:46 PM
Can't be. It has no rear wiper, and i think that the GTUs has engine speed sensitive stearing.
I can only assume that my car was purchased with from the factory with LSD. Or some random shizle like that.
_Tones_
May 25, 2021 05:37 AM
kkev.7788
West RX-7 Forum
Sep 2, 2015 02:13 AM
