S4 AFM ECU Code???
Old Nov 13, 2003 | 07:33 PM
j200pruf's Avatar
RIP Icemark
S4 AFM ECU Code???
Hey all, Well I am getting closer to starting the car, but today I plugged in the battery to make sure that everything was plugged in correctly.
Well my test lights gave the AFM code (light 1 two short lights pause and repeat). So I took it out and did all of the tests on it I could (using a multimeter and the FSM) and everything checked out.
Does this mean that the ECU or AFM is broken? Or could making some new grounds be helpful?
Old Nov 13, 2003 | 08:04 PM
nashman69g's Avatar
Boost Addict
When I was working on my car it kept giving me that same code...everything was ok and I got the car started...I could never figure out what the actual problem was! Just do some cursing and mad dance and it might just fix the problem(it worked for me)!
Old Nov 13, 2003 | 08:07 PM
J-Rat's Avatar
Alcohol Fueled!
Check your afm connector for recessed pins or corrosion.
Jarrett
Old Nov 13, 2003 | 08:08 PM
j200pruf's Avatar
RIP Icemark
Crazy dance, kicking ****, and swearing haven't fixed it yet
All of the pins on both the AFM and connector seem to be in great shape.
Old Nov 13, 2003 | 09:50 PM
reamia's Avatar
n332 is the ecu code
Old Nov 14, 2003 | 12:02 AM
j200pruf's Avatar
RIP Icemark
Actually your wrong dude, its a n326, and that isn't even the question that I asked. Try reading the whole post slick.
Old Nov 14, 2003 | 01:21 AM
j200pruf's Avatar
RIP Icemark
And something else to say, if I have the car on (not started) and move the flapper door, there is a noise in the engine bay, kinda sounds like it pumps fuel or something like that.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
ZacMan
Sep 19, 2015 09:20 PM
