weight reduction?
Old Nov 13, 2003 | 01:04 PM
4g63turbotsi's Avatar
weight reduction?
i have a 86 base,
can i take my BAC out and if i can, then can all the stuff that is attached to it go too?, also can i fit on 2, 4 piston brembo calipers in the front and in the back 2, 2 piston brembos
Old Nov 13, 2003 | 01:15 PM
Pinfield357's Avatar
do some research first before posting plz
Old Nov 13, 2003 | 01:20 PM
Rxmfn7's Avatar
Do a barrel roll!
Yes, you can remove the BAC, but the question is , why would you want to? The BAC (Bypass air control ) valve is used to stabalize the idle of the car under any load conditions (electrical, braking, etc..) There is nothing to be gained by removing the BAC.
Old Nov 13, 2003 | 01:25 PM
BlackIceGuitar's Avatar
Wieght reduction?
you need more then those few oz. off
Old Nov 13, 2003 | 02:25 PM
you may want to read the braking system thread.. it's awesome, also if your talking weight reduction you might want to consider messing with the cosmtic stuff and leaving the engine alone, besides the obvious air pump, somg and juck...
Old Nov 13, 2003 | 07:56 PM
Snrub's Avatar
If you want to upgrade your brakes, why not swap to 5-lug and use the stock aluminum 4 piston calipers. These are the same calipers as on the 3rd Gen RX-7. What exactly do you have in mind that you need those brakes?
Old Nov 13, 2003 | 09:37 PM
You do not need more braking power than the stock 5-lug 4 piston calipers can provide with an 86 base without any major mods.
MILOS7
May 9, 2016 06:39 AM
