A throttle ratled question.
Old Nov 12, 2003 | 12:00 AM
BlackIceGuitar's Avatar
What would cause a 7 to stall out, when it isn't moving. (we are talking about even if the rpms are held higher then idle. 4.5k or more)
Old Nov 12, 2003 | 12:12 AM
Erk's Avatar
Erk
1 day Sober! Never drunk again!
Vac leak, blow engine, a chicken stuck in the radiator, god knows.
Old Nov 12, 2003 | 12:16 AM
Lightbulb
ya, i just wondered....my tps is going out, i know there are no vac leaks.....
hmm...maybe that damn chicken
Old Nov 12, 2003 | 12:39 AM
anyone else?
Old Nov 12, 2003 | 12:58 AM
Icemark's Avatar
How do you know there are no vac leaks?
Spray a little starting fluid around the intake and vac lines and their connections and see if the RPM goes up. If it does, there is a vac leak.
I am assuming (based on your sig) that there are not any cats still on the car???
Old Nov 12, 2003 | 01:29 AM
nope, no cats.
I have checked for vac leaks, thats how i know.
Old Nov 12, 2003 | 01:48 AM
J-Rat's Avatar
Alcohol Fueled!
Can it be held over 4500 indefinately? Or does it die?
Old Nov 12, 2003 | 12:25 PM
it stalls even well above idle.
Old Nov 12, 2003 | 01:41 PM
....someone
Old Nov 12, 2003 | 01:46 PM
Rpeck's Avatar
What R U thinking self?
Compression test, Fuel Filter (don't forget the fuel pump filter also) , Pull codes on ECU, inspect injectors. Check for propper igntion at all plugs. Do the common sense things first
Old Nov 12, 2003 | 01:59 PM
HAILERS's Avatar
HAILERS
Disconnect the tps plug. Try again. If it does not die...then the tps has internal problems. The tps is designed to cut fuel/injector output, when you are driving along and then let off the throttle. To see this....put a meter on your primary injector and go for drive. Look at the voltage at the injector. Now let off the throttle. WAlla. Fuel cut.
So disconnect the plug and see if that makes a difference.
LongDuck
Oct 7, 2015 08:12 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
vish86
Interior / Exterior / Audio
Oct 1, 2015 11:53 PM
