Replace your pulsation dampener!!!
Old Nov 10, 2003 | 04:21 PM
Rxmfn7's Avatar
Do a barrel roll!
Upon teardown of my 88 Turbo2 for my N/A -> T2 swap, I pulled the primary fuel rail off, and pulled the cap off to inspect the PD. As soon as I pulled the cap off, fuel dribbled out, and the little screw in the PD fell to the ground. I drove the car home through 5 states like this!! Left go, its almost assured that the engine wouldve caught fire.. Please go replace the PD if you have a S4.. Dont let your car go down in flames!!
Old Nov 10, 2003 | 04:54 PM
Dvst8's Avatar
Going for the win
Re: Replace your pulsation dampener!!!
And Most importantly your wasting expensive gas!!!
Old Nov 10, 2003 | 04:56 PM
hIGGI's Avatar
strange, have banjo bolt and still bad gas mileage.....must be leaking somewhere else
Old Nov 10, 2003 | 06:05 PM
Project84's Avatar
Open up! Search Warrant!
I bought another banjo bolt to replace the PD. Now there is no PD to leak.
Old Nov 10, 2003 | 07:13 PM
88IntegraLS's Avatar
Displacement > Boost
Where is a good place to get a new pulsation damper from, other than the dealer?
Old Nov 10, 2003 | 07:27 PM
Icemark's Avatar
Mazdatrix has the S4 PDs for under $130 last I looked.
And remember the S5 PDs can leak as well. They have a little rubber stopper at the end that can leak just as easy as a screw coming out, so just like the S4; replace the S5 rail/PD every 100K as well.
Old Nov 10, 2003 | 08:06 PM
Relisys190's Avatar
REINCARNATED
Hey Mildice. would installing a banjo bolt suffice?
-markus
"It would do away with the PD, BUT.. would drivability suffer at all?"
Old Nov 10, 2003 | 09:14 PM
Pinfield357's Avatar
there has been much debate about replacing the PD with a banjo bolt.cause if it where just that easy to fix the problem then y woud mazda and damn near every other car manufacturer still us some sort of a PD on every FI car?
but i have a banjo bolt in place of my PD and have seen no ill effects
Old Nov 10, 2003 | 09:34 PM
Icemark's Avatar
-markus
well on the S5 you could not replace the PD with a bolt. The PD and rail are all one part.
On the S4, you can replace the PD with a bolt, however
(and that is a big however) Although many people claim that using the bolt will have no bad effects. But...
as posted before:
the PD takes out pulses from the injectors opening and closing.
Just like if you suddenly slammed/turned off the water in your sink, you'll hear a clunk of the fluid as it stops in the pipes (or in our case the fuel rail). Every hear a cluck when the valve for your toilet stops filling the tank? its the same idea.
Well that clunk is happening once every firing of the engine... so what? Thats about 1800 times a minute at idle, a large clunk from just one injector switching on and then off... well alone the two that happen on each fuel rail. And what happens when there is two or four injectors firing??? Could there now be pressure waves from the injectors opening and closing? Yep. So maybe now, with nothing to absorb those pressure waves, one injector may not be getting the full amount of fuel pressure...
I know what your thinking next," Whooops you mean the engine could go lean only on one injector???"
Sure can, but maybe it only goes lean at 4000 RPM to 5000 RPM or maybe only 2500-3500 RPM that shouldn't effect the motor right??? And to top it off, its almost impossible to trace down why it's going lean, unless you are looking for shock wave in the fuel rail.
there is a reason why PDs are on every imported fuel injected car made in the last 20 years, and every domestic fuel injected car for the last 10. It's because there are too many fuel issues from lines being stressed and breaking to injectors running lean because nothing is controlling the shockwave, if you don't have a PD.
Old Nov 10, 2003 | 09:41 PM
Relisys190's Avatar
REINCARNATED
good to know. thank you
-Markus
Old Nov 10, 2003 | 09:43 PM
Rxmfn7's Avatar
Do a barrel roll!
So knowing this Mark..did you replace it with a BB, or buy a new PD? Would there be anything wrong with just putting that screw back in the PD, maybe with a bit of locktite on it?
Old Nov 10, 2003 | 10:14 PM
Icemark's Avatar
On both; I replaced them. The rebuilt S4 13BT that I put in the vert before; I used a custom receiver/holder and GM performance PD. On the current motor, the rebuilt S4 13B with S5 intake I replaced the PD with a brand new S4 one. I like the S4 PD/rail design better as it allows easy changing or upgrading of the PD (although I did have to swap PD sides when using the S4 rail lower rail with the S5 intake because of clearence issues).
As far as replacing the screw, it is very very difficult to get it in the correct depth. Its common to see someone put the screw back in too deep (and rip the membrain) or not allow enough PD travel, or too shallow and have the PD not dampen enough and then rip from too much travel.
Old Nov 10, 2003 | 11:11 PM
ajsuper7's Avatar
Nothin But a G Thang
ill just reiterate what i wrote in my own post about my recent fire and another thread about the pd...my car just went up in flames most likely b/c of this so i urge everyone to do whatever is nessesary to keep their pd's from leaking...its not fun fighting a fire with a garden hose you had to grap from a random persons house.
Old Nov 10, 2003 | 11:40 PM
silverrotor's Avatar
I have suggested this before and feel confident to do so again. On s4's, you could simply pop the cover off the Primary Fuel Rail and put a liberal dab of Silicone Sealant on It. Of course, after putting the screw back In place. I did this 4ys ago with no adverse effects.
Old Nov 11, 2003 | 12:18 AM
hypntyz7's Avatar
Who wrote the above quote?
Old Nov 11, 2003 | 12:20 AM
Icemark's Avatar
The quote in my post???
I did on TeamFC3S.org
Old Nov 11, 2003 | 01:49 AM
Impreza2RX7's Avatar
Just do the Parallel fuel rail mod.
Old Nov 11, 2003 | 05:25 AM
Me? Tony Divitaris
Old Nov 14, 2003 | 07:35 AM
JGard18's Avatar
My car is an 87, with 53,500 miles. The engine was replaced about 6,000 miles ago. Should I be safe with my PD for a while?
Old Nov 14, 2003 | 07:52 AM
banzaitoyota's Avatar
What Subscription?
Another reason to get qualified for MAZDACOMP!!!!! New S4 PD is 74.00 CHEEP INSURANCE
Old Nov 14, 2003 | 08:38 AM
Peruvianrx7's Avatar
hey guys my car has 160k on it. IS the pulsation damper suppose to have a clicking sound to it? or is this asign that a screw i sloose?
Old Nov 14, 2003 | 10:08 AM
Icemark's Avatar
a clicking sound while the engine is running means that the PD is working.
However you can not gauge if the screw is in on a S4 PD unless you pop the plastic cap off.
Old Nov 14, 2003 | 10:14 AM
however you cannot gauge ? what do u mean by that is their a way to check it?
Old Nov 14, 2003 | 10:18 AM
Icemark's Avatar
POP THE PLASTIC CAP OFF AND LOOK
Old Nov 14, 2003 | 10:23 AM
thanx icemark sorry for my newbiness. if i take teh cap off and no fuel is leaking then it shoudl eb fine ill replace it anyways in about 3 to 6 thousand miles thanx
