ACT SS clutch limit?
Old Nov 8, 2003 | 07:03 PM
zooq's Avatar
whats the most whp you single turbo guys got before the ACT SS clutch started slipping?
isn't it rated at 400 lbs of torque, so thats about 350WTQ ?
Old Nov 9, 2003 | 07:17 AM
zooq's Avatar
Also, do i need to buy a whole new 6 puck clutch kit or can i just buy the 6 puck disk from ACT and use it with the SS kit?
Old Nov 9, 2003 | 10:19 AM
CCarlisi's Avatar
Rebreaking things
My friend thinks his is slipping at around 400rwhp, but IS NOT CERTAIN. When the clutch is engaged the pressure plate is what determines how much power it can hold. Therefore, you may be better off upgrading to the extreme pressure plate and sticking with the SS disk. I spoke to ACT recently about the durability of their 6-puck compared to the SS disk. They said the SS disk will outlast the 6-puck by a good margin under all conditions but drop clutch launches.
Here is some more info:
https://www.rx7club.com/showthread.p...&highlight=act
Old Nov 9, 2003 | 03:04 PM
Sl0w7's Avatar
i also want to know this... i have this clutch... she has about 6000 miles on her now... and i am putting a pretty large SFP kit on and should be making 550 or so on C16... so i know i will need a new clutch... i just want to know how far i can take it...
-Keith
Old Nov 9, 2003 | 04:52 PM
zooq's Avatar
Can you use the ACT HD pressure plate with the RB sprung hub 6 puck disk??
the RB sprung hub 6 puck disk costs $155
the unsprung 6 puck disk is $100
the ACT 6 puck is $114
is the sprung hub worth the extra $55 and will i feel the difference on the street?
Old Nov 9, 2003 | 08:37 PM
Carl Byck's Avatar
Mad Man
Go with the Extreme PP, and a 6 puck. You will smoke the SS disc all the time, and it will not last. You are in a range of power output that requires a bronze puck disc, or a multiplate IMHO. I have run an Extreme PP with a SS disc up to ~350ftlbs, it holds fine once engaged, but is easy to overheat if you slip it at all. carl
Old Nov 11, 2003 | 08:07 PM
http://www.daikin-clutch.com/product...esentation.pdf
I am a Direct Dealer of Daikin & Exedy
http://www.mitsubishigraveyard.com/direct.html
Old Nov 11, 2003 | 10:42 PM
spoolin's Avatar
well, i have an agressive streetport and a 60-1. i went to the track the other night and ran a 12.1@122mph. i could smell my clutch in my car 2/3 down the track. i am probably going to get the extreme pp and the racing beat or pineapple sprung hub for smoother engagement.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
The1Sun
Sep 15, 2015 04:45 PM
risingsunroof82
Sep 9, 2015 08:06 PM
