Direct Fire...
Old Nov 8, 2003 | 05:46 PM
K-Tune's Avatar
FD Daily
Direct Fire...
just got my 2nd jen coil pack and ignitor. what's left in order to convert to direct fire?? i have extra spark plug wires...do i need another coil? and does anyone have a wiring diagram for this..in the other write-ups they dont use this coil pack/ignitor, but everyone said this was the way to do it.
Old Nov 8, 2003 | 05:58 PM
toxic_d's Avatar
Here you go...
http://www.geocities.com/cd23c/dlidfis.html
Old Nov 8, 2003 | 05:59 PM
wwilliam54's Avatar
it WILL run
if you use a 2nd gen coil you cant use first gen igniters
just fyi
Old Nov 8, 2003 | 06:08 PM
toxic_d's Avatar
oh yeah... ww is right I didn't see that
Old Nov 8, 2003 | 06:17 PM
K-Tune's Avatar
FD Daily
so..what the heck do i use? lol i thought i heard that ALL i need as far as parts go..would be the 2nd gen coil pack and ignitor.
one of dese..
Old Nov 8, 2003 | 06:18 PM
toxic_d's Avatar
the link that I gave you will not work with that pack I read one somewhere here with that setup... sorry I cannot help more than that
Old Nov 8, 2003 | 06:19 PM
toxic_d's Avatar
Oh you could drop a second gen engine in...
Old Nov 8, 2003 | 06:21 PM
K-Tune's Avatar
FD Daily
i plan to do a T2 swap in the near future. just doing what i can with these parts...
Old Nov 8, 2003 | 06:26 PM
wwilliam54's Avatar
it WILL run
you might be able to use gm hei igniters, but i dont know
jeff20b would be a good person to ask
Old Nov 8, 2003 | 06:39 PM
85RX7GS's Avatar
You CAN use the 1st Gen ignitor (J-109) to fire the 2nd Gen ignition coil for direct fire on the leading plugs. The process is simple.
Step one:
Look at your stock leading ignition coil (closest to the strut tower). It has "+" and "-" terminals. Run two wires with eyehooks on either end from your stock leading coil to the 2nd Gen coil. Now remove the leading coil to distributor wire.
Step two:
Mount your 2nd Gen coil (when I had it installed, I bolted it to the strut tower). Disconnect the wiring on the "+" and "-" terminals of the 2nd Gen coil and put the new connections on the studs (those wires that you just made in step one). Don't forget to solder the ballast resistor (located beneath the ignitor backing plate) inline with the positive lead.
Step three:
Take your two leading plug wires and connect L1 on the engine to L1 on the coil. Do the same for L2. Now go to the distributor. Pull the trailing wires off and connect them to the leading terminals, i.e., connect "T" to "L", "T1" to "L1" and "T2" to "L2".
Step four:
Put the hood down, get in the car and start 'er up. Go for a test drive and enjoy your new FCDFIS. <----How do ya like that? FCDFIS: FC Direct Fire Ignition System. Made it up myself
Maybe inittab could add this to his FAQ?? I've even got a couple of diagrams from various ignition systems that I've tried that could be scanned or digitized if there is a need. Heck, I could even teach people how to install DLIDFIS in 20 minutes. Anyway, hope it helps.
Old Nov 8, 2003 | 06:44 PM
FD Racer's Avatar
sold the FD...kept the FB
read this thread before you install it
https://www.rx7club.com/forum/showth...hreadid=116654
Old Nov 8, 2003 | 06:53 PM
wwilliam54's Avatar
it WILL run
sweet
Old Nov 8, 2003 | 06:58 PM
K-Tune's Avatar
FD Daily
Step one:
Step two:
Step three:
Step four:
ok...when you say in step 1 for the wiring, there are currently 3 wires on my 2nd gen thingy. im connecting + and - to the + and - there..but there is also a black wire. is this the ballast you mentioned?
Old Nov 8, 2003 | 07:02 PM
K-Tune's Avatar
FD Daily
ah..i took a small cover off the 2nd gen pack. there are 2 nuts there..this is where i attach the wires going to my leading coil?
Old Nov 8, 2003 | 07:17 PM
K-Tune's Avatar
FD Daily
ah...ok i looked at the pic from the other guy, he didn't do anything with that wire. what the heck are you talking about soldering? i can't see anything...unless i unscrew that back plate...
Old Nov 8, 2003 | 07:38 PM
85RX7GS's Avatar
Alright, I went and dug out my FCDFIS so I can tell you how I wired in the resistor. You can do it this way or the way I have explained it above, whatever works for you.
Quick and dirty way to wire up FCDFIS
Here's what ya gotta do. Unscrew the four retaining screws on back of the FC ignitor. Then, take your soldering iron and loosen the solder joints (there are a couple). With the joints loose, remove the FC ignitor and feed it to your dog or something....dogs smell anyway Now, with the ignitor out, you'll have a mess of wires to look at. Coming into the ignitor "holder" assembly, and looking from left to right, there are the following wires: black, pink, and two yellow. What you want to do is solder "black" to "pink" and "yellow" to "yellow". By doing this, you'll have soldered the ballast resistor inline with the positive coil terminal. Now, if you wire the coil exactly as I've described in this post, the yellow wire (on one end of the resistor) goes to the positive terminal on the stock FB coil and the pink wire goes to the negative terminal. Essentially, you're just using the FB coil studs as a junction, so as to "jump" the signal over to the FC coil. It's easy, trust me. A squirrel with an acorn up his nads can do this Just follow the wires from terminal to terminal, double check your wiring and you're good to go.
Old Nov 8, 2003 | 08:53 PM
K-Tune's Avatar
FD Daily
err..to make this even easier..couldn't i just cut these wires? lmao. then use a connector to make these connections...
Old Nov 8, 2003 | 09:13 PM
K-Tune's Avatar
FD Daily
guess so *snip*
Old Nov 8, 2003 | 09:29 PM
QuagmireMan's Avatar
Registered Offender
is this like a distributorless ignition? or am i thinking of something different
Old Nov 8, 2003 | 10:33 PM
Jeff20B's Avatar
Lapping = Fapping
Glen, it's known as a semi-distributorless igniton system. It still uses the reluctor and magnetic pickup down inside the dizzy, but the cap and rotor are no longer used to 'distribute' the spark on the leading circuit. Trailing is still normal, other than going through the leading part of the cap (better contacts and all that).
I have an MSD 6AL that will be getting an FC leading coil so the CID 400 volts (or whatever it is lol) won't have to split into two seperate coils. It's better to DIS you CID.
Having said that, I do like the FCDFIS idea. It is cheaper, afterall. No bulky red box to buy. I may try it some day. I just don't like the requirement of using a ballast resistor.
Does anyone here know if FCDFIS needs the ballast resistor when using a GM HEI ignitor? Anyone have a spare ignitor to sacrifice?
Old Nov 9, 2003 | 09:09 AM
K-Tune's Avatar
FD Daily
why do i even need the stock FB leading coil? it just has 2 wires going to it now...lol, why cant i just yank that sucker out and run the wires directly to my FC coil?
Old Nov 9, 2003 | 10:38 AM
mwatson184's Avatar
holley guy
^ I was wondering the same thing
-Marques
Old Nov 9, 2003 | 11:12 AM
K-Tune's Avatar
FD Daily
ta da...
started right up the first time
thx for the help guys...
Old Nov 9, 2003 | 12:34 PM
85RX7GS's Avatar
You can do that. I just thought it would be easier to leave it in it's hole and jump the wires. Always glad to help. Looks very nice.
Old Nov 9, 2003 | 01:28 PM
Jeff20B's Avatar
Lapping = Fapping
Awesome! Hey, how does it run?
