Microtech emissions testing
Old Nov 8, 2003 | 08:57 AM
Silver88GXL's Avatar
emissions testing
Well, in about two hours or so, I am taking the car to get a prostate check, er emissions test. uggg, always a nervous time. But this year it is different. The microtech has me a bit concerned. Not so much the visual inspection since there really isn't one in georgia, but the tuning. I have an electric airpump that will be on durring the whole test, so the cat will be nice and hot, but ......
Anyway, wish me luck.
Old Nov 8, 2003 | 12:15 PM
BTW-I have the electric air pump set to turn on via RPM but was wondering what setting I might want to have for turning the pump on also with the vacuum signal (mainly for normal driving). Anyone know what the settings were for the oem computer?
Thanks
Old Nov 8, 2003 | 01:57 PM
Ok, well, I failed. Ugg. Oh well, there were a few things that I forgot I had set, such as 0 degrees of timing split and around 20-29 degrees of timing for the normal timing in the testing rpm ranges.
Talked to brandon and he gave me a few tips to lean the car out. Anyway, what you all have been waiting for, the numbers. air pump was injecting air the whole time of the test including idle.
25mph test (high speed, low load)
HC
Reading-659 Allowed-174
CO%
Reading-6.32 Allowed-1.12
15mph test (low speed, high load)
HC
Reading-1018 Allowed-180
CO%
Reading-10.41 Allowed-1.01
Would have loved to see my numbers without the cat on the car.
Old Nov 9, 2003 | 05:36 PM
10sec rx7's Avatar
if you lean it out your hydrocarbons are going to go through the roof more, you need to have it on a perfect 14.7:1 then throw 1gal dentured alky with 2gal fuel and you will pass no problems at all
dale
Old Nov 9, 2003 | 11:54 PM
rx7_turbo2's Avatar
Professor D.P
See if you can't bribe the operator. That's my plan for if that retarded program ever comes to my part of the country.
Old Nov 10, 2003 | 07:39 PM
dale
Brandon said the car is running about 13.1. He said I should lean it out till the engine acts kinda funny then click is a couple times towards rich.
I guess i could get some denatured alky and toss it in there also.
Old Nov 10, 2003 | 08:12 PM
10sec rx7's Avatar
the car runs at 13.0 on cruse? or on power??
you need at say 20inhg 14.7:! at 15 as close as you can get to 14.7:1
do this and throw some alky in the tank and you will pass no problems at all
Dale
Old Nov 10, 2003 | 09:22 PM
Crusader_9x's Avatar
whenver i put one gallon of denatured alky in my tank it only lowered the second number. it didnt do **** for the first number. also that was on stock computer so im not sure if it will affect anything or not. although it took my second number form not quite that high down to .02.
Old Nov 10, 2003 | 09:26 PM
10sec rx7's Avatar
ok get the mixtures to 14.7:1 and then put the alky in the tank and see what happens,
im sure you will pass.
Dale
Old Nov 11, 2003 | 02:18 PM
Dale
Okay, i got it leaned out a bit, not sure how much, need a wideband to tell. Also, couldn't find denatured alky so I got Isopropel. Will that work??
Old Nov 11, 2003 | 04:37 PM
10sec rx7's Avatar
That should work, im guessing it is pretty much the same, just remember when the testing is done to drain the tank and fill it with fresh gas as the alky is corosive
Dale
Old Nov 12, 2003 | 09:54 PM
silverrotor's Avatar
Isopropel Is In It's purest form - 100% alchohol.
RedBaronII
Sep 20, 2015 11:29 AM
Mps_hell
Sep 19, 2015 10:02 PM
ZacMan
Sep 19, 2015 09:20 PM
localized
Sep 15, 2015 08:23 PM
