will this pump hold 550whp??
Old Nov 7, 2003 | 12:28 PM
zooq's Avatar
here is the link from summitt:
Pump
Old Nov 7, 2003 | 12:33 PM
nyt's Avatar
nyt
no.
Old Nov 7, 2003 | 12:45 PM
vosko's Avatar
Just Call Me Terminator!
dual bosch motorsports should be able to do it
Old Nov 7, 2003 | 01:21 PM
BDC's Avatar
BDC
BDC Motorsports
Two of those would but one won't.
B
Old Nov 7, 2003 | 02:22 PM
Jason's Avatar
The one
I use that pump in my car and so far its good for 506 RWHP. Its rated at 1000HP.
Jason
Old Nov 7, 2003 | 03:00 PM
lok33's Avatar
Not tryin to be an *** but how do you plan to get 550 rwhp?
Old Nov 7, 2003 | 03:20 PM
maxcooper's Avatar
WWFSMD
There is not enough information there to tell you for sure if it would be enough for 550 RWHP. But at 500 lbs/hr at 45 psi and 12V, it seems like it might be enough. You'll be running it at a higher pressure than that under boost, so the single rating and even more useless "HP ratings" don't really tell you enough to be certain. The 500lbs/45psi/12v data point is pretty impressive, though, so that leads me to think that it might be enough.
-Max
Old Nov 7, 2003 | 07:55 PM
zooq's Avatar
Race ported motor
T70 BB with .84 A/R
custom manifold and 3 inch DP
PFC with 2 1300 and 2 850s
Rebic3 with 2 720s
4 inch MP and EX.
NPR large IC
all i need to do now is install that **** and tune it. i don't want to make 550 whp now, because i'm almost broke now and can't afford a new clutch.
Whats the max WHP you guys got out of a ACT SS clutch before it started smoking and slipping?
Jason: do you sell the pump for the same price as summitt?
Old Nov 7, 2003 | 10:04 PM
maxcooper's Avatar
WWFSMD
With those injectors, a BSFC of 0.62, base fuel pressure of 40 psi, injector duty cycle of 77%, 15% drivetrain losses, 22 psi of boost, 10 psi of fuel system pressure drop, you should be able to support 553 RWHP and will need 403 lbs/hr of fuel flow at 72 psi. The might be cutting it close if the pump drops the output a lot (500 lbs/hr @ 45 psi @ 12v, down to ??? lbs/hr at 72 psi @ ??v).
You can play with the numbers here:
http://www.maxcooper.com/rx7/how-to/...tem/calcs.html
It might be easier to tune without the Rebic, running 2x850+2x1684 cc/min injectors, and 50 psi base fuel pressure. But you will likely need more fuel pump since the fuel pressure will need to be higher.
-Max
Old Nov 8, 2003 | 07:49 PM
crispeed's Avatar
'Tuna'
The pump is safe up to about 500 rwhp on a rotary. It depends on how much boost which also determines the fuel pressure you'll be running to make the power. The pumps support about 650 rwhp at 70 psi of fuel pressure but that's on piston motors!: I've made 720 rwhp at 13 psi of boost on a piston motor with that pump. Normaly on a good sumped system the pump would start to drop off around 520 to 530 rwhp on a rotary.
Old Nov 9, 2003 | 04:53 AM
zooq's Avatar
so do you think putting my supra pump inline would be a good indea, to keep the pressure up?
Old Nov 9, 2003 | 10:57 AM
sub-zero's Avatar
zoog, I am using this with pump with a T-72@ 50 PSI base pressure and it had enough fuel to 24 PSI. It could support a few couple more pounds because I was running afr`s in the lower 10`s. I keep My eye on the fuel pressure gauge and I have never seen a pressure drop. I dont know what RWHP I was making this year but last year I was running the Apex RX6 and was at 380 RWHP and it did not compare to the amount of power I was making this year with a T-72. I am running a large street port with a .96 hot side. Jason just tuned His car for over 500 RWHP so I think You wil be safe unless You want to run over 25 PSI
I think You might need bigger secondaries.
Old Nov 9, 2003 | 01:23 PM
zooq's Avatar
why would i need bigger secondaries, i already have the rebic for the extra fuel . with the 2 extra 720s i'll have about 5740 cc . isn't that good enough for about 550 whp. i wanted to sell the rebic and do 1600s but i don't know if they can support 550whp. and if they are not enough, i'll not be able to go any bigger because of the PFC.
2 1600s and 2 850s = 4900cc
2 1300 , 2 850s and 2 720s = 5740cc
Old Nov 10, 2003 | 10:08 AM
sub-zero's Avatar
Sorry missed that about the Rebic.
Old Nov 10, 2003 | 12:45 PM
Marcel Burkett's Avatar
I am presently runnin' into problems with that pump , I am runnin 4 850cc's and 2 1300cc's , sumped fuel tank and PAXTON 1:1 regulator . I am also runnin a half bridged motor with a Garrett TA51 turbocharger , at 15psi boost (for now) and 9000rpm's my fuel pressure starts to fall from about 52 psi to 45 psi , my static (idle ) pressure is set at 37 psi , a/f ratios start to move from 11 , 11.2 up to 12.5 !! , and injector duty cycles at 88 % .
I am going to put another pump (or two) in the tank to suppliment the fuel supply flow / pressure. Another local racer experienced the same thing and he fixed it by puttin a SUPRA TT pump in tank and joining it to the A1000 discharge.
Old Nov 10, 2003 | 04:55 PM
zooq's Avatar
has anyone so far maxed out 2 walbro intank pumps?
this might cost me alot less to do, i can sell my used supra pump for $100 and then get 2 new walbros for $210. and i'll just run the stock lines for a while untill i notice fuel pressure drop.
will the 2 walbros handle 2 850s, 2 1300s and 2 720s at say 70-75 psi?
Old Nov 10, 2003 | 05:27 PM
kabooski's Avatar
Laying Down Rotary Law
This is going to be my fuel setup:
right now I got a Walbro"Intank" 255 High Pressure Fuel Pump
I plan to add a "Inline" Walbro 255
going thru a surge tank/swirl pot system
Aussie style
you will NEVER starv for fuel with this system period!
Old Nov 10, 2003 | 05:59 PM
zooq's Avatar
when you say inline, you mean that you'll cut the feed line and put it there
(tank with intank pump)---------(another pump)-------motor--------return to intank pump ???
Old Nov 10, 2003 | 06:50 PM
kabooski's Avatar
Old Nov 11, 2003 | 03:07 AM
zooq's Avatar
thank you very much
do you realy need the surge tank ?
Old Nov 13, 2003 | 08:34 PM
andericus mack's Avatar
Zooq, Robert is going to do a ss lines, AN fittings,
aeromotive 1000hp pump, sumped tank- whole 9 yards on mycar- he can do same for you....its just money!
Old Nov 14, 2003 | 01:29 PM
oops, I think that may be the pump I was considering.
I may need to rethink that mod. I'm a long way from
maxing the cosmo pump anyway.
Old Nov 14, 2003 | 03:44 PM
SPOautos's Avatar
Hey, where did my $$$ go?
A Weldon 2025 would be a great pump....its expensive though
STEPHEN
Old Nov 14, 2003 | 04:46 PM
zooq's Avatar
STEPHEN
isn't that pump loud enough that you can hear over a vented WG.
